pdeliot 10 Posted February 6, 2023 Posted February 6, 2023 Since update to 4.7.0.60 the option "Only not already in library" do not to work cross library anymore. For example, if you have a separate libraries for transcoded series, or to store other source... DVR is recording existing episodes. That was NOT the case in previous build. It was spoken about a way to optionnaly enable previous behavior. Is there any clear plan to have a way get back to previous beahvior?
Luke 42242 Posted February 21, 2023 Posted February 21, 2023 Hi, yes we can look at adding more options to control this. Thanks for the feedback. 1
pdeliot 10 Posted August 15, 2023 Author Posted August 15, 2023 Is this will be available in 4.8 final? At most?
Luke 42242 Posted August 15, 2023 Posted August 15, 2023 13 hours ago, pdeliot said: Is this will be available in 4.8 final? At most? Hi, we are working on getting 4.8 ready for release. Thanks.
