ReadySalted 9 Posted February 5, 2023 Posted February 5, 2023 I've seen a few topics about this but links in there are dead and information there is not clear to follow. Currently, HDR is watchable in Theater, just a little dark. Boosting HDR balance in Windows also affects Windows itself so I don't want that, I just want to boost Emby video, like peak nits or play with other things. Do I need to update mpv or does Theater come with the latest? If I need to update it, how do I do it? I also need to know about the mpv.conf. Last time I tried creating a file and copying text into it, video wouldn't play.
Solution Happy2Play 9811 Posted February 5, 2023 Solution Posted February 5, 2023 13 minutes ago, ReadySalted said: I've seen a few topics about this but links in there are dead and information there is not clear to follow. Currently, HDR is watchable in Theater, just a little dark. Boosting HDR balance in Windows also affects Windows itself so I don't want that, I just want to boost Emby video, like peak nits or play with other things. Do I need to update mpv or does Theater come with the latest? If I need to update it, how do I do it? I also need to know about the mpv.conf. Last time I tried creating a file and copying text into it, video wouldn't play. Have you tried installing the Diagnostics plugin and changing the tone mapping algorithm?
ReadySalted 9 Posted February 5, 2023 Author Posted February 5, 2023 I never knew about these options but that's simple to do and much easier than I expected, thank you.
