dg74403 0 Posted February 5, 2023 Posted February 5, 2023 How do I clear out unused devices? I'm upgrading my devices and reached my limit on devices.
GrimReaper 4894 Posted February 5, 2023 Posted February 5, 2023 2 minutes ago, dg74403 said: I'm upgrading my devices and reached my limit on devices What do you mean by that? You've reached Premiere limit?
dg74403 0 Posted February 5, 2023 Author Posted February 5, 2023 I have tried to connect a new device. When I did this after I input the username and password to sign in I keep going through a loop of inputting my username and password. I can't connect.
GrimReaper 4894 Posted February 5, 2023 Posted February 5, 2023 4 minutes ago, dg74403 said: I have tried to connect a new device. When I did this after I input the username and password to sign in I keep going through a loop of inputting my username and password. I can't connect. That is likely some other issue that has nothing to do with the number of devices you're connecting from. See:
Happy2Play 9811 Posted February 5, 2023 Posted February 5, 2023 (edited) 16 minutes ago, dg74403 said: I'm upgrading my devices and reached my limit on devices. What does Status say on App Settings-Emby Premiere? Device limits do not apply to logging in only functionality. Only User Device Access could do that. Edited February 5, 2023 by Happy2Play
ebr 16332 Posted February 5, 2023 Posted February 5, 2023 14 hours ago, GrimReaper said: That is likely some other issue that has nothing to do with the number of devices you're connecting from. See: Correct as the device limit will never keep you from connecting. It only governs Premiere features.
