danergo 40 Posted February 2, 2023 Posted February 2, 2023 Hi Team! I have a little problem with the transcoding. First of all: thank you for this amazing software. During playback on a webos TV, when I select bandwidth limitation, in "stats for nerds" it still shows direct play. (But when checking in my router, the setting actually works - this is just a small notice. My Emby on the TV just have updated to latest version). So, I wish to know if I can somehow change the ffmpeg arguments during transcode. Being far from the Linux server with no HW transcode capabilities, I wish to try some other ffmpeg configurations which might work better on my network. Also a bit off: can I utilize USB graphics cards for HW transcode? Anyone has experience with it?
danergo 40 Posted February 2, 2023 Author Posted February 2, 2023 Like CBR/VBR, preset, buffer size, probesize, etc, I don't really know as of know I just wanted to ask if it is at all possible. Thank you!
Solution Luke 42245 Posted February 2, 2023 Solution Posted February 2, 2023 If you really want to, the diagnostics plugin has a search and replace feature that you can use to change the ffmpeg command line. 1
