b0mb 36 Posted February 8, 2023 Author Posted February 8, 2023 (edited) ok it seems like it belongs to the Skin how good its looking... with Estuary Skin its looking and working fine but with Arctic Horizon 2 its not.... Edited February 8, 2023 by b0mb
TeamB 2440 Posted February 9, 2023 Posted February 9, 2023 11 hours ago, b0mb said: ok it seems like it belongs to the Skin how good its looking... with Estuary Skin its looking and working fine but with Arctic Horizon 2 its not.... My custom dialog was using some assets from the default base skin, this causes issues when switching skins. I have removed all base skin assets now and re-scaled the new dialog correctly. The latest version has the following changes: - a setting in add-on services tab to enable/disable using this new custom bookmark dialog - removed all base skin assets, it should display correctly now regardless of the base skin used (at the bottom just above the controls of the video OSD) - only trigger when triggered using the video OSD bookmark activation button
b0mb 36 Posted February 9, 2023 Author Posted February 9, 2023 this Solution is good.... the Thumbs are now also shown in the correct ratio thx! 1
