shackbill 22 Posted February 2, 2023 Posted February 2, 2023 Is there Voice Control support on any Samsung TVs such as searching for movies or tv shows etc.. i have several Samsungs of various ages and although a couple of them have Bixby voice control, they dont seem to extend to Emby at all. I think i read somewhere that natively they only support Netflix and Amazon Prime. Just curious. 3
Luke 42239 Posted February 3, 2023 Posted February 3, 2023 Hi, yes it's on our list for review. We're not sure yet if it's something that's available to all third party apps or not. 1
LiamW 0 Posted July 4, 2024 Posted July 4, 2024 Do you have any updates on this by any chance? I have noticed that I can use the microphone anywhere that the default keyboard is called. Could this be used as a work around if you aren’t able to insert a microphone button directly into the Emby app search?
Luke 42239 Posted July 5, 2024 Posted July 5, 2024 On 7/3/2024 at 10:36 PM, LiamW said: Do you have any updates on this by any chance? I have noticed that I can use the microphone anywhere that the default keyboard is called. Could this be used as a work around if you aren’t able to insert a microphone button directly into the Emby app search? Hi, yes this is something we plan to look at. Thanks.
