Neminem 1623 Posted April 2, 2025 Posted April 2, 2025 @cnstarzyou can delay or / and require a mount to be accessible before you start a docker. 1
cnstarz 27 Posted April 2, 2025 Author Posted April 2, 2025 6 hours ago, Neminem said: @cnstarzyou can delay or / and require a mount to be accessible before you start a docker. Thanks but that affects all Docker containers, not just my Emby one.
Neminem 1623 Posted April 2, 2025 Posted April 2, 2025 Well its better than Emby removing all you metadata. I pretty sure you can do some health check in you Emby docker compose, to check if your mount is online. A quick search and I found this. I don't need to do this, as my unRaid server checks mounts on startup. In unRaid I can even set a docker startup delay on select docker containers, that I want to start delayed. 1
