cnstarz 27 Posted February 2, 2023 Posted February 2, 2023 (edited) I'm running Emby using your Docker container on a host that is separate from my NAS. I've had several times now where my home has lost power and I will absent-mindedly start my Emby container before my NAS has fully booted. This results in Emby thinking there is no longer any media, therefore all the metadata and images for all of my libraries get erased. Then, when the NAS gets powered back on, and I restart Emby, it now has to rebuild every library. I have 46TB of movies and tv shows -- rebuilding the database can take over a day. Not only that, it resets the "Date Added" value for everything, so now everything's "Date Added" value is right now, which is obviously unintended. Is there a setting that exists or can be added to prevent Emby from clearing out a library in the event that a library has gone offline? Edited February 2, 2023 by cnstarz
cnstarz 27 Posted February 2, 2023 Author Posted February 2, 2023 (edited) @Happy2Play 4.7.11.0 Edited February 2, 2023 by cnstarz
Happy2Play 9812 Posted February 2, 2023 Posted February 2, 2023 4 minutes ago, cnstarz said: @Happy2Play 4.7.11.0 Might be some changes in 4.8 but don't know the details.
Luke 42243 Posted February 2, 2023 Posted February 2, 2023 We'd have to look at a specific example of this along with the Emby Server log, but I believe this will be improved with the upcoming 4.8 release.
cnstarz 27 Posted February 2, 2023 Author Posted February 2, 2023 @Luke Here's the log from when I first lost power. 2023-02-01 05:41:53.166 Info Main: Application path: /system/EmbyServer.dll 2023-02-01 05:41:53.600 Info Main: Emby Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-137-generic (buildd@lcy02-amd64-009) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #154-Ubuntu SMP Thu Jan 5 17:03:22 UTC 20 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system 2023-02-01 05:41:53.600 Info Main: Logs path: /config/logs 2023-02-01 05:41:53.600 Info Main: Cache path: /config/cache 2023-02-01 05:41:53.600 Info Main: Internal metadata path: /config/metadata 2023-02-01 05:41:53.601 Info Main: Transcoding temporary files path: /config/transcoding-temp 2023-02-01 05:41:53.650 Info App: Application version: 4.7.11.0 2023-02-01 05:41:53.653 Info App: Loading assemblies 2023-02-01 05:41:53.720 Info App: File /config/plugins/Emby.Dlna.dll has version 1.0.92.0 2023-02-01 05:41:53.724 Info App: File /system/plugins/Emby.Dlna.dll has version 1.0.91.0 2023-02-01 05:41:53.727 Info App: File /config/plugins/Emby.PortMapper.dll has version 1.1.8.0 2023-02-01 05:41:53.729 Info App: File /system/plugins/Emby.PortMapper.dll has version 1.1.8.0 2023-02-01 05:41:53.732 Info App: File /config/plugins/Fanart.dll has version 1.0.13.0 2023-02-01 05:41:53.735 Info App: File /system/plugins/Fanart.dll has version 1.0.13.0 2023-02-01 05:41:53.740 Info App: File /config/plugins/Emby.Server.CinemaMode.dll has version 1.0.40.0 2023-02-01 05:41:53.743 Info App: File /system/plugins/Emby.Server.CinemaMode.dll has version 1.0.40.0 2023-02-01 05:41:53.750 Info App: File /config/plugins/MovieDb.dll has version 1.6.2.0 2023-02-01 05:41:53.753 Info App: File /system/plugins/MovieDb.dll has version 1.6.2.0 2023-02-01 05:41:53.759 Info App: File /config/plugins/OpenSubtitles.dll has version 1.0.31.0 2023-02-01 05:41:53.762 Info App: File /system/plugins/OpenSubtitles.dll has version 1.0.31.0 2023-02-01 05:41:53.767 Info App: File /config/plugins/Emby.XmlTV.dll has version 1.0.9.0 2023-02-01 05:41:53.769 Info App: File /system/plugins/Emby.XmlTV.dll has version 1.0.9.0 2023-02-01 05:41:53.772 Info App: File /config/plugins/Emby.M3UTuner.dll has version 1.0.13.0 2023-02-01 05:41:53.774 Info App: File /system/plugins/Emby.M3UTuner.dll has version 1.0.13.0 2023-02-01 05:41:53.775 Info App: File /config/plugins/EmbyGuideData.dll has version 1.0.10.0 2023-02-01 05:41:53.777 Info App: File /system/plugins/EmbyGuideData.dll has version 1.0.10.0 2023-02-01 05:41:53.780 Info App: File /config/plugins/NfoMetadata.dll has version 1.0.70.0 2023-02-01 05:41:53.783 Info App: File /system/plugins/NfoMetadata.dll has version 1.0.70.0 2023-02-01 05:41:53.786 Info App: File /config/plugins/Tvdb.dll has version 1.3.4.0 2023-02-01 05:41:53.788 Info App: File /system/plugins/Tvdb.dll has version 1.3.3.0 2023-02-01 05:41:53.791 Info App: File /config/plugins/DvdMounter.dll has version 1.0.0.0 2023-02-01 05:41:53.794 Info App: File /system/plugins/DvdMounter.dll has version 1.0.0.0 2023-02-01 05:41:53.797 Info App: File /config/plugins/OMDb.dll has version 1.0.18.0 2023-02-01 05:41:53.800 Info App: File /system/plugins/OMDb.dll has version 1.0.18.0 2023-02-01 05:41:53.802 Info App: File /config/plugins/BlurayMounter.dll has version 1.0.0.0 2023-02-01 05:41:53.806 Info App: File /system/plugins/BlurayMounter.dll has version 1.0.0.0 2023-02-01 05:41:53.808 Info App: File /config/plugins/MusicBrainz.dll has version 1.0.22.0 2023-02-01 05:41:53.810 Info App: File /system/plugins/MusicBrainz.dll has version 1.0.22.0 2023-02-01 05:41:53.811 Info App: File /config/plugins/StudioImages.dll has version 1.0.3.0 2023-02-01 05:41:53.813 Info App: File /system/plugins/StudioImages.dll has version 1.0.3.0 2023-02-01 05:41:53.815 Info App: File /config/plugins/AudioDb.dll has version 1.0.16.0 2023-02-01 05:41:53.816 Info App: File /system/plugins/AudioDb.dll has version 1.0.16.0 2023-02-01 05:41:53.821 Info App: File /config/plugins/Emby.Webhooks.dll has version 1.0.25.0 2023-02-01 05:41:53.824 Info App: File /system/plugins/Emby.Webhooks.dll has version 1.0.25.0 2023-02-01 05:41:53.880 Info App: Loading Emby.Dlna, Version=1.0.92.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Dlna.dll 2023-02-01 05:41:53.880 Info App: Loading Emby.PortMapper, Version=1.1.8.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.PortMapper.dll 2023-02-01 05:41:53.880 Info App: Loading Fanart, Version=1.0.13.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Fanart.dll 2023-02-01 05:41:53.880 Info App: Loading Emby.Server.CinemaMode, Version=1.0.40.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Server.CinemaMode.dll 2023-02-01 05:41:53.880 Info App: Loading MovieDb, Version=1.6.2.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MovieDb.dll 2023-02-01 05:41:53.880 Info App: Loading OpenSubtitles, Version=1.0.31.0, Culture=neutral, PublicKeyToken=null from /config/plugins/OpenSubtitles.dll 2023-02-01 05:41:53.880 Info App: Loading Emby.XmlTV, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.XmlTV.dll 2023-02-01 05:41:53.880 Info App: Loading Emby.M3UTuner, Version=1.0.13.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.M3UTuner.dll 2023-02-01 05:41:53.880 Info App: Loading EmbyGuideData, Version=1.0.10.0, Culture=neutral, PublicKeyToken=null from /config/plugins/EmbyGuideData.dll 2023-02-01 05:41:53.880 Info App: Loading AutoBoxSets, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null from /config/plugins/AutoBoxSets.dll 2023-02-01 05:41:53.880 Info App: Loading NfoMetadata, Version=1.0.70.0, Culture=neutral, PublicKeyToken=null from /config/plugins/NfoMetadata.dll 2023-02-01 05:41:53.880 Info App: Loading statistics, Version=3.0.5.1, Culture=neutral, PublicKeyToken=null from /config/plugins/Statistics.dll 2023-02-01 05:41:53.880 Info App: Loading Tvdb, Version=1.3.4.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Tvdb.dll 2023-02-01 05:41:53.880 Info App: Loading DvdMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /config/plugins/DvdMounter.dll 2023-02-01 05:41:53.880 Info App: Loading EmbyReports, Version=1.0.44.0, Culture=neutral, PublicKeyToken=null from /config/plugins/EmbyReports.dll 2023-02-01 05:41:53.880 Info App: Loading OMDb, Version=1.0.18.0, Culture=neutral, PublicKeyToken=null from /config/plugins/OMDb.dll 2023-02-01 05:41:53.880 Info App: Loading BlurayMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /config/plugins/BlurayMounter.dll 2023-02-01 05:41:53.880 Info App: Loading MBBackup, Version=1.4.9.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MBBackup.dll 2023-02-01 05:41:53.880 Info App: Loading MusicBrainz, Version=1.0.22.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MusicBrainz.dll 2023-02-01 05:41:53.880 Info App: Loading StudioImages, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /config/plugins/StudioImages.dll 2023-02-01 05:41:53.880 Info App: Loading AudioDb, Version=1.0.16.0, Culture=neutral, PublicKeyToken=null from /config/plugins/AudioDb.dll 2023-02-01 05:41:53.880 Info App: Loading Emby.Webhooks, Version=1.0.25.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Webhooks.dll 2023-02-01 05:41:53.880 Info App: Loading MediaBrowser.Plugins.Anime, Version=1.5.3.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MediaBrowser.Plugins.Anime.dll 2023-02-01 05:41:53.880 Info App: Loading Emby.Api, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading Emby.Web, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading MediaBrowser.Model, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading MediaBrowser.Common, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading MediaBrowser.Controller, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading Emby.Providers, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading Emby.Photos, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading Emby.Server.Implementations, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading Emby.LiveTV, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading Emby.ActivityLog, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading Emby.Server.MediaEncoding, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading Emby.LocalMetadata, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading Emby.Notifications, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading Emby.Codecs.Dxva, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading Emby.Codecs, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading Emby.Server.Connect, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.880 Info App: Loading Emby.Server.Sync, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:53.881 Info App: Loading EmbyServer, Version=4.7.11.0, Culture=neutral, PublicKeyToken=null 2023-02-01 05:41:54.440 Info SqliteUserRepository: Sqlite version: 3.39.2 2023-02-01 05:41:54.441 Info SqliteUserRepository: Sqlite compiler options: ATOMIC_INTRINSICS=1,COMPILER=gcc-10.3.0,DEFAULT_AUTOVACUUM,DEFAULT_CACHE_SIZE=-2000,DEFAULT_FILE_FORMAT=4,DEFAULT_JOURNAL_SIZE_LIMIT=-1,DEFAULT_MMAP_SIZE=0,DEFAULT_PAGE_SIZE=4096,DEFAULT_PCACHE_INITSZ=20,DEFAULT_RECURSIVE_TRIGGERS,DEFAULT_SECTOR_SIZE=4096,DEFAULT_SYNCHRONOUS=2,DEFAULT_WAL_AUTOCHECKPOINT=1000,DEFAULT_WAL_SYNCHRONOUS=2,DEFAULT_WORKER_THREADS=0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS4,ENABLE_FTS5,ENABLE_GEOPOLY,ENABLE_MATH_FUNCTIONS,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MALLOC_SOFT_LIMIT=1024,MAX_ATTACHED=10,MAX_COLUMN=2000,MAX_COMPOUND_SELECT=500,MAX_DEFAULT_PAGE_SIZE=8192,MAX_EXPR_DEPTH=1000,MAX_FUNCTION_ARG=127,MAX_LENGTH=1000000000,MAX_LIKE_PATTERN_LENGTH=50000,MAX_MMAP_SIZE=0x7fff0000,MAX_PAGE_COUNT=1073741823,MAX_PAGE_SIZE=65536,MAX_SCHEMA_RETRY=25,MAX_SQL_LENGTH=1000000000,MAX_TRIGGER_DEPTH=1000,MAX_VARIABLE_NUMBER=250000,MAX_VDBE_OP=250000000,MAX_WORKER_THREADS=8,MUTEX_PTHREADS,OMIT_LOOKASIDE,SECURE_DELETE,SYSTEM_MALLOC,TEMP_STORE=1,THREADSAFE=1 2023-02-01 05:41:54.441 Info SqliteUserRepository: Opening sqlite connection to /config/data/users.db 2023-02-01 05:41:54.595 Info SqliteUserRepository: Default journal_mode for /config/data/users.db is wal 2023-02-01 05:41:54.710 Info ActivityRepository: Opening sqlite connection to /config/data/activitylog.db 2023-02-01 05:41:54.773 Info ActivityRepository: Default journal_mode for /config/data/activitylog.db is wal 2023-02-01 05:41:54.780 Info SqliteDisplayPreferencesRepository: Opening sqlite connection to /config/data/displaypreferences.db 2023-02-01 05:41:54.802 Info NetworkManager: Detecting local network addresses 2023-02-01 05:41:54.802 Info NetworkManager: networkInterface: Ethernet eth0, Speed: 10000000000, Description: eth0 2023-02-01 05:41:54.802 Info NetworkManager: GatewayAddresses: 172.17.0.1 2023-02-01 05:41:54.803 Info NetworkManager: UnicastAddresses: 172.17.0.5 2023-02-01 05:41:54.803 Info NetworkManager: networkInterface: Loopback lo, Speed: -1, Description: lo 2023-02-01 05:41:54.803 Info NetworkManager: GatewayAddresses: 2023-02-01 05:41:54.803 Info NetworkManager: UnicastAddresses: 127.0.0.1 2023-02-01 05:41:54.805 Info NetworkManager: Detected local ip addresses: 172.17.0.5, 127.0.0.1 2023-02-01 05:41:54.807 Info SqliteDisplayPreferencesRepository: Default journal_mode for /config/data/displaypreferences.db is wal 2023-02-01 05:41:54.822 Info App: Adding HttpListener prefix http://+:8096/ 2023-02-01 05:41:55.171 Info AuthenticationRepository: Opening sqlite connection to /config/data/authentication.db 2023-02-01 05:41:55.191 Info AuthenticationRepository: Default journal_mode for /config/data/authentication.db is wal 2023-02-01 05:41:55.194 Info SqliteItemRepository: Opening sqlite connection to /config/data/library.db 2023-02-01 05:41:55.244 Info SqliteItemRepository: Default journal_mode for /config/data/library.db is wal 2023-02-01 05:41:55.245 Info SqliteItemRepository: cache_size is -98304 2023-02-01 05:41:55.245 Info SqliteItemRepository: page_size is 4096 2023-02-01 05:41:56.637 Info FfmpegManager: FFMpeg: /bin/ffmpeg 2023-02-01 05:41:56.638 Info FfmpegManager: FFProbe: /bin/ffprobe 2023-02-01 05:41:56.639 Info FfmpegManager: FFDetect: /bin/ffdetect 2023-02-01 05:41:56.651 Info Skia: SkiaSharp version: 2.80.0.0 2023-02-01 05:41:56.715 Info TaskManager: Daily trigger for Configuration Backup set to fire at 02/02/2023 00:10:00, which is 1108.054747585 minutes from now. 2023-02-01 05:41:56.717 Info TaskManager: Daily trigger for Thumbnail image extraction set to fire at 02/02/2023 02:00:00, which is 1218.0547022883334 minutes from now. 2023-02-01 05:41:57.100 Info TaskManager: Daily trigger for Rotate log file set to fire at 02/02/2023 00:00:00, which is 1098.0483176283333 minutes from now. 2023-02-01 05:41:57.156 Info App: ServerId: 9871b241e21f47f690d70a932b6d4a9a 2023-02-01 05:41:57.231 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2023-02-01 05:41:57.268 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.0367091 seconds 2023-02-01 05:41:57.268 Info App: Starting entry point Emby.Server.Implementations.Networking.RemoteAddressEntryPoint 2023-02-01 05:41:57.269 Info App: Loading data from /config/data/wan.dat 2023-02-01 05:41:57.275 Info App: Entry point completed: Emby.Server.Implementations.Networking.RemoteAddressEntryPoint. Duration: 0.0072981 seconds 2023-02-01 05:41:57.275 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2023-02-01 05:41:57.277 Info App: Loading data from /config/data/connect.txt 2023-02-01 05:41:57.278 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0026361 seconds 2023-02-01 05:41:57.278 Info App: Core startup complete 2023-02-01 05:41:57.278 Info App: Post-init migrations complete 2023-02-01 05:41:57.278 Info App: Starting entry point Emby.PortMapper.ExternalPortForwarding 2023-02-01 05:41:57.279 Info App: Entry point completed: Emby.PortMapper.ExternalPortForwarding. Duration: 0.0007384 seconds 2023-02-01 05:41:57.279 Info App: Starting entry point Emby.Security.PluginSecurityManager 2023-02-01 05:41:57.279 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 3.84E-05 seconds 2023-02-01 05:41:57.279 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2023-02-01 05:41:57.279 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.0001138 seconds 2023-02-01 05:41:57.279 Info App: Starting entry point NfoMetadata.EntryPoint 2023-02-01 05:41:57.280 Info App: Entry point completed: NfoMetadata.EntryPoint. Duration: 0.0004795 seconds 2023-02-01 05:41:57.280 Info App: Starting entry point Tvdb.EntryPoint 2023-02-01 05:41:57.280 Info App: Entry point completed: Tvdb.EntryPoint. Duration: 3.9E-05 seconds 2023-02-01 05:41:57.280 Info App: Starting entry point MBBackup.ServerEntryPoint 2023-02-01 05:41:57.280 Info App: Entry point completed: MBBackup.ServerEntryPoint. Duration: 3.26E-05 seconds 2023-02-01 05:41:57.280 Info App: Starting entry point Emby.Notifications.NotificationManager 2023-02-01 05:41:57.287 Info NotificationManager: Registering event nofitier Webhooks 2023-02-01 05:41:57.293 Info App: Entry point completed: Emby.Notifications.NotificationManager. Duration: 0.0134562 seconds 2023-02-01 05:41:57.293 Info App: Starting entry point Emby.Webhooks.ConfigurationUpgradeEntryPoint 2023-02-01 05:41:57.297 Info App: Entry point completed: Emby.Webhooks.ConfigurationUpgradeEntryPoint. Duration: 0.0037892 seconds 2023-02-01 05:41:57.297 Info App: Starting entry point Emby.Api.ApiEntryPoint 2023-02-01 05:41:57.297 Info App: Entry point completed: Emby.Api.ApiEntryPoint. Duration: 4.18E-05 seconds 2023-02-01 05:41:57.297 Info App: Starting entry point Emby.Server.Implementations.Udp.UdpServerEntryPoint 2023-02-01 05:41:57.300 Info App: Entry point completed: Emby.Server.Implementations.Udp.UdpServerEntryPoint. Duration: 0.0030013 seconds 2023-02-01 05:41:57.300 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint 2023-02-01 05:41:57.301 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.0004278 seconds 2023-02-01 05:41:57.301 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2023-02-01 05:41:57.347 Info LibraryMonitor: Skipping realtime monitor for /mnt/media/misc because the path is currently not available 2023-02-01 05:41:57.347 Info LibraryMonitor: Skipping realtime monitor for /mnt/media/movies-uhd because the path is currently not available 2023-02-01 05:41:57.347 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.0466756 seconds 2023-02-01 05:41:57.347 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2023-02-01 05:41:57.348 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0007599 seconds 2023-02-01 05:41:57.348 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2023-02-01 05:41:57.349 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0002917 seconds 2023-02-01 05:41:57.349 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2023-02-01 05:41:57.351 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0024934 seconds 2023-02-01 05:41:57.351 Info LibraryMonitor: Watching directory /mnt/media/tv 2023-02-01 05:41:57.351 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2023-02-01 05:41:57.351 Info LibraryMonitor: Watching directory /mnt/media/movies 2023-02-01 05:41:57.354 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0023422 seconds 2023-02-01 05:41:57.354 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2023-02-01 05:41:57.354 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.0003117 seconds 2023-02-01 05:41:57.354 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2023-02-01 05:41:57.354 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0003938 seconds 2023-02-01 05:41:57.354 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2023-02-01 05:41:57.355 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0001119 seconds 2023-02-01 05:41:57.355 Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint 2023-02-01 05:41:57.357 Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.0022576 seconds 2023-02-01 05:41:57.357 Info App: Starting entry point Emby.LiveTV.EntryPoint 2023-02-01 05:41:57.360 Info LiveTV: Loading live tv data from /config/data/livetv/timers 2023-02-01 05:41:57.380 Info App: Entry point completed: Emby.LiveTV.EntryPoint. Duration: 0.0229145 seconds 2023-02-01 05:41:57.380 Info App: Starting entry point Emby.LiveTV.UpgradeChannelOptionsEntryPoint 2023-02-01 05:41:57.381 Info App: Entry point completed: Emby.LiveTV.UpgradeChannelOptionsEntryPoint. Duration: 0.0013177 seconds 2023-02-01 05:41:57.381 Info App: Starting entry point Emby.LiveTV.RecordingNotifier 2023-02-01 05:41:57.382 Info App: Entry point completed: Emby.LiveTV.RecordingNotifier. Duration: 0.0006051 seconds 2023-02-01 05:41:57.382 Info App: Starting entry point Emby.ActivityLog.ActivityLogEntryPoint 2023-02-01 05:41:57.383 Info App: Entry point completed: Emby.ActivityLog.ActivityLogEntryPoint. Duration: 0.0013924 seconds 2023-02-01 05:41:57.383 Info App: Starting entry point Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint 2023-02-01 05:42:00.121 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2023-02-01 05:42:00.164 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Execute: /bin/ffmpeg -hide_banner -version 2023-02-01 05:42:00.218 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Process exited with code 0 - Succeeded 2023-02-01 05:42:00.381 Info SoftwareCodecProvider: h264, libx264, x264 Software Encoder, V-E-libx264 2023-02-01 05:42:00.381 Info SoftwareCodecProvider: hevc, libx265, x265 Software Encoder, V-E-libx265 2023-02-01 05:42:00.381 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg4 2023-02-01 05:42:00.381 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg4 2023-02-01 05:42:00.381 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2023-02-01 05:42:00.383 Info SoftwareCodecProvider: h264, libx264, x264 Software Encoder, V-E-libx264 2023-02-01 05:42:00.383 Info SoftwareCodecProvider: hevc, libx265, x265 Software Encoder, V-E-libx265 2023-02-01 05:42:00.383 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg4 2023-02-01 05:42:00.383 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg4 2023-02-01 05:42:00.383 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2023-02-01 05:42:00.397 Info VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Execute: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 vaencdec -print_format json 2023-02-01 05:42:00.418 Info VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Process exited with code 0 - Succeeded 2023-02-01 05:42:00.493 Info VaapiCodecProvider: Adapter #0: 'GM107 GeForce GTX 750 Ti' Id:4992 (Driver: , Vendor: NVIDIA Corporation) 2023-02-01 05:42:00.497 Info QuickSyncCodecProvider: ProcessRun 'ffdetect_qsvencdec' Execute: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 qsvencdec -print_format json 2023-02-01 05:42:00.513 Info QuickSyncCodecProvider: ProcessRun 'ffdetect_qsvencdec' Process exited with code 0 - Succeeded 2023-02-01 05:42:00.573 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Execute: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 nvencdec -print_format json 2023-02-01 05:42:00.956 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Process exited with code 0 - Succeeded 2023-02-01 05:42:01.022 Info NvidiaCodecProvider: Adapter #0: 'NVIDIA GeForce GTX 750 Ti' ComputeCapability: 5.0 2023-02-01 05:42:01.252 Info CodecManager: CodecList: Decoders mpeg2video CUVID NVIDIA GeForce GTX 750 Ti - MPEG-2 NVDEC NVIDIA GeForce GTX 750 Ti - MPEG-2 vc1 NVDEC NVIDIA GeForce GTX 750 Ti - VC-1 h264 CUVID NVIDIA GeForce GTX 750 Ti - H.264 (AVC) NVDEC NVIDIA GeForce GTX 750 Ti - H.264 (AVC) Encoders h264 NVENC NVIDIA GeForce GTX 750 Ti - H.264 (AVC) 2023-02-01 05:42:01.420 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint. Duration: 4.0363316 seconds 2023-02-01 05:42:01.420 Info App: Starting entry point Emby.Notifications.Notifications 2023-02-01 05:42:01.420 Info App: Entry point completed: Emby.Notifications.Notifications. Duration: 0.0005013 seconds 2023-02-01 05:42:01.420 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2023-02-01 05:42:01.426 Info App: SyncRepository Initialize taking write lock 2023-02-01 05:42:01.426 Info App: SyncRepository Initialize write lock taken 2023-02-01 05:42:01.426 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0054881 seconds 2023-02-01 05:42:01.426 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2023-02-01 05:42:01.428 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0023728 seconds 2023-02-01 05:42:01.428 Info App: Starting entry point EmbyServer.Windows.LoopUtilEntryPoint 2023-02-01 05:42:01.428 Info App: Entry point completed: EmbyServer.Windows.LoopUtilEntryPoint. Duration: 0.0001447 seconds 2023-02-01 05:42:01.428 Info App: All entry points have started 2023-02-01 05:42:57.106 Info LibraryMonitor: Stopping directory watching for path /mnt/media/tv 2023-02-01 05:42:57.107 Info LibraryMonitor: Stopping directory watching for path /mnt/media/movies 2023-02-01 05:42:57.283 Error App: Error in AddResolvedExtras for misc 0 /mnt/media/misc *** Error Report *** Version: 4.7.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-137-generic (buildd@lcy02-amd64-009) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #154-Ubuntu SMP Thu Jan 5 17:03:22 UTC 20 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path '/mnt/media/misc'. at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound) at System.IO.Enumeration.FileSystemEnumerator`1.Init() at System.IO.Enumeration.FileSystemEnumerator`1..ctor(String directory, Boolean isNormalized, EnumerationOptions options) at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized) at System.IO.Enumeration.FileSystemEnumerableFactory.FileSystemInfos(String directory, String expression, EnumerationOptions options, Boolean isNormalized) at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options) at System.IO.DirectoryInfo.EnumerateFileSystemInfos(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path, Boolean clearCache) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.Entities.BaseItem.GetFileSystemChildren(IDirectoryService directoryService) at Emby.Server.Implementations.Library.LibraryManager.AddResolvedExtras(BaseItem item, IDirectoryService directoryService) Source: System.Private.CoreLib TargetSite: IntPtr CreateDirectoryHandle(System.String, Boolean) 2023-02-01 05:42:57.286 Error App: Error in AddResolvedExtras for movies-uhd 0 /mnt/media/movies-uhd *** Error Report *** Version: 4.7.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-137-generic (buildd@lcy02-amd64-009) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #154-Ubuntu SMP Thu Jan 5 17:03:22 UTC 20 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path '/mnt/media/movies-uhd'. at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound) at System.IO.Enumeration.FileSystemEnumerator`1.Init() at System.IO.Enumeration.FileSystemEnumerator`1..ctor(String directory, Boolean isNormalized, EnumerationOptions options) at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized) at System.IO.Enumeration.FileSystemEnumerableFactory.FileSystemInfos(String directory, String expression, EnumerationOptions options, Boolean isNormalized) at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options) at System.IO.DirectoryInfo.EnumerateFileSystemInfos(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path, Boolean clearCache) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.Entities.BaseItem.GetFileSystemChildren(IDirectoryService directoryService) at Emby.Server.Implementations.Library.LibraryManager.AddResolvedExtras(BaseItem item, IDirectoryService directoryService) Source: System.Private.CoreLib TargetSite: IntPtr CreateDirectoryHandle(System.String, Boolean) 2023-02-01 05:42:57.356 Error App: Error getting files from /mnt/media/misc *** Error Report *** Version: 4.7.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-137-generic (buildd@lcy02-amd64-009) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #154-Ubuntu SMP Thu Jan 5 17:03:22 UTC 20 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path '/mnt/media/misc'. at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound) at System.IO.Enumeration.FileSystemEnumerator`1.Init() at System.IO.Enumeration.FileSystemEnumerator`1..ctor(String directory, Boolean isNormalized, EnumerationOptions options) at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized) at System.IO.Enumeration.FileSystemEnumerableFactory.FileSystemInfos(String directory, String expression, EnumerationOptions options, Boolean isNormalized) at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options) at System.IO.DirectoryInfo.EnumerateFileSystemInfos(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path, Boolean clearCache) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetFiles(String[] paths, Boolean throwOnException, IDirectoryService directoryService) Source: System.Private.CoreLib TargetSite: IntPtr CreateDirectoryHandle(System.String, Boolean) 2023-02-01 05:42:57.364 Error App: Error getting files from /mnt/media/movies-uhd *** Error Report *** Version: 4.7.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-137-generic (buildd@lcy02-amd64-009) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #154-Ubuntu SMP Thu Jan 5 17:03:22 UTC 20 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path '/mnt/media/movies-uhd'. at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound) at System.IO.Enumeration.FileSystemEnumerator`1.Init() at System.IO.Enumeration.FileSystemEnumerator`1..ctor(String directory, Boolean isNormalized, EnumerationOptions options) at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized) at System.IO.Enumeration.FileSystemEnumerableFactory.FileSystemInfos(String directory, String expression, EnumerationOptions options, Boolean isNormalized) at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options) at System.IO.DirectoryInfo.EnumerateFileSystemInfos(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path, Boolean clearCache) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetFiles(String[] paths, Boolean throwOnException, IDirectoryService directoryService) Source: System.Private.CoreLib TargetSite: IntPtr CreateDirectoryHandle(System.String, Boolean) 2023-02-01 05:42:57.371 Error App: Error getting files from /mnt/media/misc *** Error Report *** Version: 4.7.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-137-generic (buildd@lcy02-amd64-009) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #154-Ubuntu SMP Thu Jan 5 17:03:22 UTC 20 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path '/mnt/media/misc'. at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound) at System.IO.Enumeration.FileSystemEnumerator`1.Init() at System.IO.Enumeration.FileSystemEnumerator`1..ctor(String directory, Boolean isNormalized, EnumerationOptions options) at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized) at System.IO.Enumeration.FileSystemEnumerableFactory.FileSystemInfos(String directory, String expression, EnumerationOptions options, Boolean isNormalized) at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options) at System.IO.DirectoryInfo.EnumerateFileSystemInfos(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path, Boolean clearCache) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetFiles(String[] paths, Boolean throwOnException, IDirectoryService directoryService) Source: System.Private.CoreLib TargetSite: IntPtr CreateDirectoryHandle(System.String, Boolean) 2023-02-01 05:42:57.372 Error App: Error getting files from /mnt/media/movies-uhd *** Error Report *** Version: 4.7.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-137-generic (buildd@lcy02-amd64-009) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #154-Ubuntu SMP Thu Jan 5 17:03:22 UTC 20 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path '/mnt/media/movies-uhd'. at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound) at System.IO.Enumeration.FileSystemEnumerator`1.Init() at System.IO.Enumeration.FileSystemEnumerator`1..ctor(String directory, Boolean isNormalized, EnumerationOptions options) at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized) at System.IO.Enumeration.FileSystemEnumerableFactory.FileSystemInfos(String directory, String expression, EnumerationOptions options, Boolean isNormalized) at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options) at System.IO.DirectoryInfo.EnumerateFileSystemInfos(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path, Boolean clearCache) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetFiles(String[] paths, Boolean throwOnException, IDirectoryService directoryService) Source: System.Private.CoreLib TargetSite: IntPtr CreateDirectoryHandle(System.String, Boolean) 2023-02-01 05:42:57.378 Error App: Error in AddResolvedExtras for misc 0 /mnt/media/misc *** Error Report *** Version: 4.7.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-137-generic (buildd@lcy02-amd64-009) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #154-Ubuntu SMP Thu Jan 5 17:03:22 UTC 20 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path '/mnt/media/misc'. at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound) at System.IO.Enumeration.FileSystemEnumerator`1.Init() at System.IO.Enumeration.FileSystemEnumerator`1..ctor(String directory, Boolean isNormalized, EnumerationOptions options) at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized) at System.IO.Enumeration.FileSystemEnumerableFactory.FileSystemInfos(String directory, String expression, EnumerationOptions options, Boolean isNormalized) at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options) at System.IO.DirectoryInfo.EnumerateFileSystemInfos(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path, Boolean clearCache) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.Entities.BaseItem.GetFileSystemChildren(IDirectoryService directoryService) at Emby.Server.Implementations.Library.LibraryManager.AddResolvedExtras(BaseItem item, IDirectoryService directoryService) Source: System.Private.CoreLib TargetSite: IntPtr CreateDirectoryHandle(System.String, Boolean) 2023-02-01 05:42:57.379 Error App: Error in AddResolvedExtras for movies-uhd 0 /mnt/media/movies-uhd *** Error Report *** Version: 4.7.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-137-generic (buildd@lcy02-amd64-009) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #154-Ubuntu SMP Thu Jan 5 17:03:22 UTC 20 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path '/mnt/media/movies-uhd'. at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound) at System.IO.Enumeration.FileSystemEnumerator`1.Init() at System.IO.Enumeration.FileSystemEnumerator`1..ctor(String directory, Boolean isNormalized, EnumerationOptions options) at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized) at System.IO.Enumeration.FileSystemEnumerableFactory.FileSystemInfos(String directory, String expression, EnumerationOptions options, Boolean isNormalized) at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options) at System.IO.DirectoryInfo.EnumerateFileSystemInfos(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path, Boolean clearCache) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.Entities.BaseItem.GetFileSystemChildren(IDirectoryService directoryService) at Emby.Server.Implementations.Library.LibraryManager.AddResolvedExtras(BaseItem item, IDirectoryService directoryService) Source: System.Private.CoreLib TargetSite: IntPtr CreateDirectoryHandle(System.String, Boolean) 2023-02-01 05:42:57.496 Info App: Removing item from database, Type: Series, Name: Better Call Saul Presents: Slippin' Jimmy, Path: /mnt/media/tv/Better Call Saul Presents - Slippin' Jimmy (2022) [imdbid-tt20516438], Id: 423022 2023-02-01 05:42:57.871 Info App: Deleting path /config/metadata/library/6b/6b6e078cec66b031c18e405d0ee4f4a7 2023-02-01 05:42:57.873 Info App: Deleting path /config/metadata/library/36/36d1a7868c89c3260d87f082c156e45f 2023-02-01 05:42:57.875 Info App: Deleting path /config/metadata/library/ea/ea19520f880c396b6176267e2b64a307 2023-02-01 05:42:57.876 Info App: Deleting path /config/metadata/library/f8/f8431eb7aaa69d26650eb917ce1a8048 2023-02-01 05:42:57.878 Info App: Deleting path /config/metadata/library/2a/2a4a8d5e36ffa900ebf94815d868a8ef 2023-02-01 05:42:57.880 Info App: Deleting path /config/metadata/library/8e/8e05a56432c47faab8bc756f9f9d6921 2023-02-01 05:42:57.880 Info App: Deleting path /config/metadata/library/ff/ffedf30159721d11cd82966de0d501f2 2023-02-01 05:42:57.882 Info App: Deleting path /config/metadata/library/de/defe4b511f9d82dd914bac47b695de42 2023-02-01 05:42:57.886 Info App: Removing item from database, Type: Series, Name: Devil in Ohio, Path: /mnt/media/tv/Devil in Ohio (2022) [imdbid-tt15432016], Id: 423023 2023-02-01 05:42:57.953 Info App: Deleting path /config/metadata/library/1a/1a1321bba1544c6f4cd08ec5a04ec779 2023-02-01 05:42:57.956 Info App: Deleting path /config/metadata/library/c6/c64c95c6de0c3b5e1940acd815312252 2023-02-01 05:42:57.959 Info App: Deleting path /config/metadata/library/f7/f78ed01f9caac3055e5a6c0d13ac2386 2023-02-01 05:42:57.960 Info App: Deleting path /config/metadata/library/4f/4f274acb23e204d8a4995e103b6113c9 2023-02-01 05:42:57.961 Info App: Deleting path /config/metadata/library/91/91211682f341090af84e07080c599a3d 2023-02-01 05:42:57.963 Info App: Deleting path /config/metadata/library/ad/ad2608489641577b845de634bde679e3 2023-02-01 05:42:57.964 Info App: Deleting path /config/metadata/library/b6/b6ad7843bfeef9a3b65d078301be1d7e 2023-02-01 05:42:57.965 Info App: Deleting path /config/metadata/library/e2/e20317a4b3b1d03a44a6b3640dcfa691 2023-02-01 05:42:57.967 Info App: Deleting path /config/metadata/library/be/beea80e5873481658371b46080ace6c7 2023-02-01 05:42:57.969 Info App: Deleting path /config/metadata/library/3b/3bf6a28d98cfa70b7d25a4d2f161159f ******************************* ******************************* <snip 19,400 lines of the same "Removing item from database..." followed by "Deleting path /config/metadata/library..."> ******************************* ******************************* 2023-02-01 05:43:30.219 Error BaseItem: Error validating children for misc 156748 /mnt/media/misc *** Error Report *** Version: 4.7.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-137-generic (buildd@lcy02-amd64-009) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #154-Ubuntu SMP Thu Jan 5 17:03:22 UTC 20 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path '/mnt/media/misc'. at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound) at System.IO.Enumeration.FileSystemEnumerator`1.Init() at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized) at System.IO.Enumeration.FileSystemEnumerableFactory.FileSystemInfos(String directory, String expression, EnumerationOptions options, Boolean isNormalized) at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options) at System.IO.DirectoryInfo.EnumerateFileSystemInfos(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path, Boolean clearCache) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.Entities.BaseItem.GetFileSystemChildren(IDirectoryService directoryService) at MediaBrowser.Controller.Entities.Folder.GetNonCachedChildren(IDirectoryService directoryService, LibraryOptions libraryOptions) at MediaBrowser.Controller.Entities.Folder.ValidateChildrenInternal(IProgress`1 progress, CancellationToken cancellationToken, Boolean recursive, Boolean refreshChildMetadata, MetadataRefreshOptions refreshOptions, IDirectoryService directoryService) at MediaBrowser.Controller.Entities.Folder.ValidateSubFolders(BaseItem[] children, IDirectoryService directoryService, IProgress`1 progress, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: IntPtr CreateDirectoryHandle(System.String, Boolean) 2023-02-01 05:43:30.314 Error BaseItem: Error validating children for movies-uhd 267329 /mnt/media/movies-uhd *** Error Report *** Version: 4.7.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.4.0-137-generic (buildd@lcy02-amd64-009) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #154-Ubuntu SMP Thu Jan 5 17:03:22 UTC 20 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path '/mnt/media/movies-uhd'. at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound) at System.IO.Enumeration.FileSystemEnumerator`1.Init() at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized) at System.IO.Enumeration.FileSystemEnumerableFactory.FileSystemInfos(String directory, String expression, EnumerationOptions options, Boolean isNormalized) at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options) at System.IO.DirectoryInfo.EnumerateFileSystemInfos(String searchPattern, SearchOption searchOption) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path, Boolean clearCache) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.Entities.BaseItem.GetFileSystemChildren(IDirectoryService directoryService) at MediaBrowser.Controller.Entities.Folder.GetNonCachedChildren(IDirectoryService directoryService, LibraryOptions libraryOptions) at MediaBrowser.Controller.Entities.Folder.ValidateChildrenInternal(IProgress`1 progress, CancellationToken cancellationToken, Boolean recursive, Boolean refreshChildMetadata, MetadataRefreshOptions refreshOptions, IDirectoryService directoryService) at MediaBrowser.Controller.Entities.Folder.ValidateSubFolders(BaseItem[] children, IDirectoryService directoryService, IProgress`1 progress, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: IntPtr CreateDirectoryHandle(System.String, Boolean) 2023-02-01 05:43:30.750 Info App: Removing item from database, Type: Movie, Name: Jeffrey Dahmer: Mind of a Monster, Path: /mnt/media/movies/Jeffrey Dahmer Mind of a Monster (2020)/Jeffrey Dahmer-Mind of a Monster (2020) [1080p].mkv, Id: 441052 2023-02-01 05:43:30.767 Info App: Deleting path /config/metadata/library/fb/fb806e9536aaead9663931cf6c9800e4 2023-02-01 05:43:30.768 Info App: Removing item from database, Type: Movie, Name: Three Billboards Outside Ebbing, Missouri, Path: /mnt/media/movies/Three Billboards Outside Ebbing, Missouri (2017)/Three Billboards Outside Ebbing, Missouri (2017) [Bluray-1080p].mkv, Id: 441053 2023-02-01 05:43:30.785 Info App: Deleting path /config/metadata/library/e1/e1f727f007f7af60d30d06cef224da5e 2023-02-01 05:43:30.786 Info App: Removing item from database, Type: Movie, Name: Killing Them Softly, Path: /mnt/media/movies/Killing Them Softly (2012)/Killing Them Softly (2012) [Bluray-1080p].mkv, Id: 441054 2023-02-01 05:43:30.803 Info App: Deleting path /config/metadata/library/59/592efa359e4c0cb0f31e5e76c3713e7f 2023-02-01 05:43:30.804 Info App: Removing item from database, Type: Movie, Name: Weekend at Bernie's, Path: /mnt/media/movies/Weekend at Bernie's (1989)/Weekend at Bernie's (1989) [Bluray-1080p].mp4, Id: 441057 2023-02-01 05:43:30.819 Info App: Deleting path /config/metadata/library/44/44c27aadb62a5be6df5e0b96fe2720a0 2023-02-01 05:43:30.821 Info App: Removing item from database, Type: Movie, Name: The Black Phone, Path: /mnt/media/movies/The Black Phone (2022)/The Black Phone (2022) [Bluray-1080p][EAC3 7.1][x264].mkv, Id: 441058 2023-02-01 05:43:30.838 Info App: Deleting path /config/metadata/library/66/66d0f2d3d79fb0985f519697cd7543b3 2023-02-01 05:43:30.839 Info App: Removing item from database, Type: Movie, Name: Power Rangers, Path: /mnt/media/movies/Power Rangers (2017)/Power Rangers (2017) [Bluray-1080p][AC3 5.1][x264].mkv, Id: 441059 2023-02-01 05:43:30.856 Info App: Deleting path /config/metadata/library/45/45eff62d9d254344f41524f7157640a2 2023-02-01 05:43:30.857 Info App: Removing item from database, Type: Movie, Name: Transporter 2, Path: /mnt/media/movies/Transporter 2 (2005)/Transporter 2 (2005) [1080p].mkv, Id: 441060 2023-02-01 05:43:30.870 Info App: Deleting path /config/metadata/library/fa/fad2835923fb77f498d433f0b5bf4ec2 2023-02-01 05:43:30.872 Info App: Removing item from database, Type: Movie, Name: Warrior, Path: /mnt/media/movies/Warrior (2011)/Warrior (2011) [Bluray-1080p][DTS 5.1][x264].mkv, Id: 441061 2023-02-01 05:43:30.888 Info App: Deleting path /config/metadata/library/2c/2c84ed4b51e749129c13f1f333b0973c 2023-02-01 05:43:30.889 Info App: Removing item from database, Type: Movie, Name: Suicide Squad: Hell to Pay, Path: /mnt/media/movies/Suicide Squad Hell to Pay (2018)/Suicide Squad Hell to Pay (2018) [Bluray-1080p].mkv, Id: 441062 2023-02-01 05:43:30.903 Info App: Deleting path /config/metadata/library/b2/b2ffd6b87703ce6efe21fcd5ea8531d7 2023-02-01 05:43:30.904 Info App: Removing item from database, Type: Movie, Name: Batman: Gotham Knight, Path: /mnt/media/movies/Batman Gotham Knight (2008)/Batman Gotham Knight (2008) [Remux-1080p].mkv, Id: 441063 2023-02-01 05:43:30.917 Info App: Deleting path /config/metadata/library/cd/cdb09fdc9e78a22d79c7cf78e964b981 2023-02-01 05:43:30.918 Info App: Removing item from database, Type: Movie, Name: Doctor Strange, Path: /mnt/media/movies/Doctor Strange (2016)/Doctor Strange (2016) [Bluray-1080p].mkv, Id: 441064 <snip 4k more lines of the same stuff>
feerlessleadr 173 Posted February 11, 2023 Posted February 11, 2023 FYI - I had the same thing happen to me. Would love to see this improved in future versions.
Luke 42243 Posted February 14, 2023 Posted February 14, 2023 OK, I think this should be improved in the upcoming 4.8 server release. Thanks. 1
feerlessleadr 173 Posted February 14, 2023 Posted February 14, 2023 Thanks @Luke . I'm assuming the improvment relates to this in the 4.8 release: Quote Stop scanning at the top of a library when it's unreachable 1
cnstarz 27 Posted September 23, 2024 Author Posted September 23, 2024 (edited) This happened again today. House experienced a power outage last night. My wife booted up the server before the NAS, resulting in Emby re-downloading all the metadata. Version 4.8.8.0 embyserver.txt Edited September 23, 2024 by cnstarz
darkassassin07 674 Posted September 23, 2024 Posted September 23, 2024 This is a direct result of how you structure your media/which folders you add to Embys libraries. You want to add folders that are contained inside the mountpoint for the external NAS. Not the mountpoint itself. For example: you have a mountpoint at /mnt/media To that, you mount a share from the nas, so the folder now contains movies: /mnt/media/Madagascar (2005)/<video files> If you add /mnt/media to an emby library; when the NAS is not mounted, the folder '/mnt/media/ still exists, but is empty. Emby sees this empty folder and thinks you've deleted all the content that was in it, so it removes it from its database. Now instead, mount a share that contains the structure /movies/Madagascar (2005)/<video files>, so you end up with: /mnt/media/movies/Madagascar (2005)/<video files> Then add /mnt/media/movies as your folder in emby. With this structure, when your NAS isn't mounted, you're left with an empty /mnt/media folder. When emby scans this, it is completely unable to find the root folder '/mnt/media/movies', instead of finding that folder but empty. Emby will then recognize the root folder is missing entirely, assume it will be back, and not remove the media from its database. As you are using docker, it's important to ensure the container sees the same behavior. Don't mount /mnt/media/movies to the container, mount /mmt/media then add the root folders (/mnt/media/movies) to Emby. If the root folders still exist when the mount isn't mounted, emby will see them as empty instead of missing and remove the content from its db. 1
Q-Droid 1011 Posted September 23, 2024 Posted September 23, 2024 This is a helpful tip for people who rely on external storage for their media. It can help prevent the loss of metadata but for many they might have to reorganize their media. And for most, they don't even know this is a problem until it hits them. The real and permanent fix would be to allow for media to be missing without flagging it as permanently deleted. This is not a new problem and the team has had plenty of time to come up with a solution.
cnstarz 27 Posted September 24, 2024 Author Posted September 24, 2024 (edited) 6 hours ago, darkassassin07 said: This is a direct result of how you structure your media/which folders you add to Embys libraries. You want to add folders that are contained inside the mountpoint for the external NAS. Not the mountpoint itself. For example: you have a mountpoint at /mnt/media To that, you mount a share from the nas, so the folder now contains movies: /mnt/media/Madagascar (2005)/<video files> If you add /mnt/media to an emby library; when the NAS is not mounted, the folder '/mnt/media/ still exists, but is empty. Emby sees this empty folder and thinks you've deleted all the content that was in it, so it removes it from its database. Now instead, mount a share that contains the structure /movies/Madagascar (2005)/<video files>, so you end up with: /mnt/media/movies/Madagascar (2005)/<video files> Then add /mnt/media/movies as your folder in emby. With this structure, when your NAS isn't mounted, you're left with an empty /mnt/media folder. When emby scans this, it is completely unable to find the root folder '/mnt/media/movies', instead of finding that folder but empty. Emby will then recognize the root folder is missing entirely, assume it will be back, and not remove the media from its database. As you are using docker, it's important to ensure the container sees the same behavior. Don't mount /mnt/media/movies to the container, mount /mmt/media then add the root folders (/mnt/media/movies) to Emby. If the root folders still exist when the mount isn't mounted, emby will see them as empty instead of missing and remove the content from its db. The docker container has only this volume which is the root of all my media: --volume /mnt/nasdata/media:/mnt/media Then in Emby, I added a 'Movies' library that points to /mnt/media/movies And a 'TV' library that points to /mnt/media/tv Sounds like I'm already doing what you're describing? Edited September 24, 2024 by cnstarz
guunter 49 Posted September 24, 2024 Posted September 24, 2024 57 minutes ago, cnstarz said: The docker container has only this volume which is the root of all my media: --volume /mnt/nasdata/media:/mnt/media Then in Emby, I added a 'Movies' library that points to /mnt/media/movies And a 'TV' library that points to /mnt/media/tv Sounds like I'm already doing what you're describing? He’s talking about the appdata itself. It’s shown in Emby as /config. You need to make it persistent and point it to a folder. Ex. - v /opt/appdata/emby:/config lifes a whole lot easier if you get comfortable with a docker compose stack. They have ones made for emby at hub.docker.com like from Linuxserver.io group 1
darkassassin07 674 Posted September 24, 2024 Posted September 24, 2024 (edited) Is the mountpoint /mnt/nasdata not empty when unmounted? Perhaps some of the folder structure was created at somepoint while the nas wasn't mounted. I'm also not sure how the optional network share paths added in emby interact with this; I've never used those. May be irrelevant, may not. I just now created a library as I described above using a usb stick as a test and my own docker setup. When I unmounted the usb, emby could no longer play the files from that library, but did not remove them after several library scans. Showing the error (in log) "Error validating children for movies /mnt/USB/movies" and "Could not find part of the path: /mnt/USB/movies" To get things working again; I did find I had to restart the emby container after remounting the usb, to get docker itself to recognize that mount had returned. Rescanning the media resulted in no changes and everything could be played once more. Edited September 24, 2024 by darkassassin07
darkassassin07 674 Posted September 24, 2024 Posted September 24, 2024 7 minutes ago, guunter said: He’s talking about the appdata itself. It’s shown in Emby as /config. You need to make it persistent and point it to a folder. Ex. - v /opt/appdata/emby:/config lifes a whole lot easier if you get comfortable with a docker compose stack. They have ones made for emby at hub.docker.com like from Linuxserver.io group While I hadn't been talking about appdata, that is a great point. If you truly only have the one volume, you definitely need to add a second for the config directory.
cnstarz 27 Posted September 24, 2024 Author Posted September 24, 2024 5 hours ago, guunter said: He’s talking about the appdata itself. It’s shown in Emby as /config. You need to make it persistent and point it to a folder. Ex. - v /opt/appdata/emby:/config lifes a whole lot easier if you get comfortable with a docker compose stack. They have ones made for emby at hub.docker.com like from Linuxserver.io group Hey now, I ain't no psychopath that doesn't include a volume for /config. I do also have a volume for /config, I just didn't mention it cuz it doesn't hold my media, lmao. 5 hours ago, darkassassin07 said: Is the mountpoint /mnt/nasdata not empty when unmounted? Perhaps some of the folder structure was created at somepoint while the nas wasn't mounted. I will have to play with this a little bit and find out
Luke 42243 Posted September 24, 2024 Posted September 24, 2024 5 hours ago, cnstarz said: Hey now, I ain't no psychopath that doesn't include a volume for /config. I do also have a volume for /config, I just didn't mention it cuz it doesn't hold my media, lmao. I will have to play with this a little bit and find out Let us know how this goes. Thanks.
guunter 49 Posted September 24, 2024 Posted September 24, 2024 7 hours ago, cnstarz said: Hey now, I ain't no psychopath that doesn't include a volume for /config. I do also have a volume for /config, I just didn't mention it cuz it doesn't hold my media, lmao. I will have to play with this a little bit and find out Just wanted to make sure. What is your scheduled tasks for scanning library? If you use a ARR stack theres no need to leave scanning library at intervals turned on. The ARR stack can tell emby when to scan for changes. But if you dont use the ARR stack im out of ideas.
cnstarz 27 Posted September 24, 2024 Author Posted September 24, 2024 1 minute ago, guunter said: Just wanted to make sure. What is your scheduled tasks for scanning library? If you use a ARR stack theres no need to leave scanning library at intervals turned on. The ARR stack can tell emby when to scan for changes. But if you dont use the ARR stack im out of ideas. I do use two instances of radarr and an instance of sonarr, so now I'm curious what setting I missed in them that tells emby to scan. It seems familiar, like the feature wasn't working or doesn't work with network shares or something. I'll have to dig into it.
guunter 49 Posted September 24, 2024 Posted September 24, 2024 6 hours ago, cnstarz said: I do use two instances of radarr and an instance of sonarr, so now I'm curious what setting I missed in them that tells emby to scan. It seems familiar, like the feature wasn't working or doesn't work with network shares or something. I'll have to dig into it. In Settings -> Connect The Update Library check mark should be telling Emby there is something new and it should scan it.
cnstarz 27 Posted September 24, 2024 Author Posted September 24, 2024 Oh yep, I have that checked. But I think there's an issue with the internal paths because the *arr containers have an internal mount of /nasdata while emby has an internal mount of /mnt/media, so it doesn't work. I tried updating the 'Map Paths From' field to '/nasdata/media' and the 'Map Paths To' field to '/mnt/media', but emby doesn't do anything when a new episode is imported, renamed, or deleted.
Luke 42243 Posted September 25, 2024 Posted September 25, 2024 Ok let us know if you find anything. Thanks.
cnstarz 27 Posted April 1, 2025 Author Posted April 1, 2025 (edited) @Luke, it freakin happened again! This time it happened after a simple server reboot. I rebooted the server -> Emby started up on its own -> bam -- no media in my Movie or TV libraries and now Emby is redownloading metadata for all of my TV shows and Movies. HOWEVER, it did have my 4K library movies (less than 50 movies). I'm guessing the Emby container was able to start before the host operating system was able to fully mount the share or know of all of its contents. This is becoming frustrating. On my server, I have the following mount: 10.0.10.12:/volume1/data on /mnt/nasdata type nfs4 (rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=10.0.10.22,local_lock=none,addr=10.0.10.12,_netdev) My Emby docker container has the following volumes: --volume /opt/docker/volumes/emby/config:/config --volume /mnt/nasdata/media:/nasdata/media For the love of God, there has to be a way to not clear out entire libraries just because the library's contents aren't available when Emby starts. I'm now forced to look up work-around hacks to prevent Emby from starting when my library paths aren't available. This is so frustrating -- it's gonna take like 2 days to download metadata for all of my TV shows and movies. Edit: sorry, was frustrated at my first-world problem. Edited April 2, 2025 by cnstarz
Luke 42243 Posted April 2, 2025 Posted April 2, 2025 4 hours ago, cnstarz said: @Luke, it freakin happened again! This time it happened after a simple server reboot. I rebooted the server -> Emby started up on its own -> bam -- no media in my Movie or TV libraries and now Emby is redownloading metadata for all of my TV shows and Movies. HOWEVER, it did have my 4K library movies (less than 50 movies). I'm guessing the Emby container was able to start before the host operating system was able to fully mount the share or know of all of its contents. This is becoming frustrating. On my server, I have the following mount: 10.0.10.12:/volume1/data on /mnt/nasdata type nfs4 (rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=10.0.10.22,local_lock=none,addr=10.0.10.12,_netdev) My Emby docker container has the following volumes: --volume /opt/docker/volumes/emby/config:/config --volume /mnt/nasdata/media:/nasdata/media For the love of God, there has to be a way to not clear out entire libraries just because the library's contents aren't available when Emby starts. I'm now forced to look up work-around hacks to prevent Emby from starting when my library paths aren't available. This is so frustrating -- it's gonna take like 2 days to download metadata for all of my TV shows and movies. Edit: sorry, was frustrated at my first-world problem. Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
