Buzzz 0 Posted February 1, 2023 Posted February 1, 2023 Hi All, I'm currently in the process of migrating from Plex to Emby. Mainly for improved Live TV function. I have 2 sources for LiveTV TvHeadend which is has 3 tuners plugged into the aerial for Terrestrial TV (Freeview) M3U for IPTV using Xteve proxy (not relevant for this but I'm providing as much info as I can) I'm using the Emby guide data source for both and this is what I used to do with Plex. For the Sky Q lineup (GBR-1000209-DEFAULT) This is working perfectly, it grabs all of the show info, images for the show + live, new repeat tags etc The Freeview Emby guide data (GBR-1000073-DEFAULT) does not grab images or show the live, new/repeat airings tags Is this just due to the source of the Emby guide data not having the images? I've tried alternate lineups like BT TV and Talk Talk and I get the same issue. Thanks
Luke 42237 Posted February 1, 2023 Posted February 1, 2023 Quote Is this just due to the source of the Emby guide data not having the images? Hi, yes this is correct. Program images come from the guide data.
Buzzz 0 Posted February 5, 2023 Author Posted February 5, 2023 Thanks, does emby use gracenote? That's what Plex uses and it grabs the images for those channels. Just checking if it's the source that's the issue?
Buzzz 0 Posted February 5, 2023 Author Posted February 5, 2023 Although looks like plex is having the same issue as well. Is there a problem with gracenote at the moment?
Luke 42237 Posted February 5, 2023 Posted February 5, 2023 Hi, yes we use gracenote. Have you tried refreshing your guide data? It seems to be working OK in my testing.
