sam089 0 Posted January 31, 2023 Posted January 31, 2023 Hey all. So I'm very new to emby. I synced my folder with all of the flac files to emby and I'm not seeing any artwork. I don't have a computer unfortunately at the moment. I looked last night at a post and tired find something useful about it to help but couldn't figure it out. I've got the server on as well using Android. My android tv has the same setup with the files showing just not metadata. I tried usjng a fetcher and without to no avail. Can someone help ??
Luke 42243 Posted January 31, 2023 Posted January 31, 2023 Hi, do your audio files have artist and album information embedded within them?
sam089 0 Posted January 31, 2023 Author Posted January 31, 2023 15 minutes ago, Luke said: Hi, do your audio files have artist and album information embedded within them? I would think so. The files are flac. Although some of them r a i f f files which have been converted to flac. Most are flac without converting. Some are beatport some are qobuz and some are Bandcamp.
Luke 42243 Posted January 31, 2023 Posted January 31, 2023 Have you examined the files using a tool such as mp3 tag or Picard?
sam089 0 Posted January 31, 2023 Author Posted January 31, 2023 15 minutes ago, Luke said: Have you examined the files using a tool such as mp3 tag or Picard? I can check that out tonight and see. I'll keep you updated.
sam089 0 Posted January 31, 2023 Author Posted January 31, 2023 22 minutes ago, sam089 said: I can check that out tonight and see. I'll keep you updated. The thing is they sbow up on my phone or if I insert a USB c stick with them on in they'll snow up with images. It's when I stream these flac files is when the artwork isn't showing up.
Luke 42243 Posted February 21, 2023 Posted February 21, 2023 @sam089 can you zip up one of these flac albums and attach it here? Thanks !
