AtlasRedux 2 Posted January 29, 2023 Posted January 29, 2023 As title states. LG C1. Dolby Atmos and HDR works fine together in EAC3. If I use TrueHD or DTS, it just pops up that it's Dolby Digital (which I assume is still Atmos) and no HDR.
Solution Happy2Play 9811 Posted January 29, 2023 Solution Posted January 29, 2023 Sound like this topic 1
AtlasRedux 2 Posted January 29, 2023 Author Posted January 29, 2023 Ah. Somehow missed that o.0 I did read through the forum, and still managed to skip over that. I'm blind apparently. Welp, guess I'll have to use USB for now then every bloody time I want to watch a movie with Atmos, TrueHD or DTS. Just upgraded my home cinema, hence didn't bother with Atmos before -.- 1
SamES 1084 Posted January 30, 2023 Posted January 30, 2023 12 hours ago, AtlasRedux said: Ah. Somehow missed that o.0 I did read through the forum, and still managed to skip over that. I'm blind apparently. Welp, guess I'll have to use USB for now then every bloody time I want to watch a movie with Atmos, TrueHD or DTS. Just upgraded my home cinema, hence didn't bother with Atmos before -.- This issue is fixed in the next webOS version (not yet released) but keep in mind that Atmos, TrueHD and DTS will still all be converted to AC3. The update will prevent the video from being converted and losing HDR, but it will not pass through Atmos, TrueHD and DTS to the receiver (DTS is no longer supported by LG, and they have not made it possible for apps to pass-through TrueHD/ATMOS). Therefore, if you already have andAC3 track in the file then you're better of selecting that track manually in the client before playback and enjoying the HDR!
AtlasRedux 2 Posted January 30, 2023 Author Posted January 30, 2023 2 minutes ago, SamES said: This issue is fixed in the next webOS version (not yet released) but keep in mind that Atmos, TrueHD and DTS will still all be converted to AC3. The EAC3 is fine, and Atmos works in EAC3. I strongly doubt anyone hear the difference from uncompressed to EAC3 anyways. But I am not converting the tons of stuff I have manually from my 50TB of storage, so I'll use the USB until the update. Good it is being fixed, I'm partially disabled and it is a pain to crawl and switch USB -.-
SamES 1084 Posted January 30, 2023 Posted January 30, 2023 EAC3 is compressed ATMOS vs TrueHD which is uncompressed - yes, EAC3 works fine and doesn't need conversion - so EAC3 or AC3 are both a good choice if you have that option - just avoid TrueHD and DTS This might be of interest Why does the Emby App for my LG TV not play the Dolby Atmos TrueHD Audio without Transcoding? :
Utini 14 Posted February 4, 2023 Posted February 4, 2023 (edited) This file has Dolby Digital AC3 and Dolby True HD Atmos. Still both channels do not have HDR when playing. It also says "Direct Play" when selecting the AC3 channel. Edit: Oh nevermind, I just realized this is not a HDR file lol? General Unique ID : 281873406801559100796370629200641459985 (0xD40ED7ED8E2A6A110969CDD2C00F0711) Complete name : /mnt/Files/Torrent_Movies/Black.Panther.Wakanda.Forever.2022.2160p.MA.WEB-DL.TrueHD.7.1.Atmos.HEVC-CMRG.mkv Format : Matroska Format version : Version 4 File size : 33.9 GiB Duration : 2 h 41 min Overall bit rate mode : Variable Overall bit rate : 30.1 Mb/s Writing application : mkvmerge v73.0.0 ('25 or 6 to 4') 64-bit Writing library : libebml v1.4.4 + libmatroska v1.7.1 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 41 min Bit rate : 24.5 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.123 Stream size : 27.6 GiB (81%) Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio #1 ID : 2 Format : MLP FBA 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Codec ID : A_TRUEHD Duration : 2 h 41 min Bit rate mode : Variable Bit rate : 4 689 kb/s Maximum bit rate : 7 758 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 1 200.000 FPS (40 SPF) Compression mode : Lossless Delay relative to video : -83 ms Stream size : 5.28 GiB (16%) Title : TrueHD Atmos 7.1 Language : English Default : Yes Forced : No Number of dynamic objects : 13 Bed channel count : 1 channel Bed channel configuration : LFE Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 41 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : -83 ms Stream size : 738 MiB (2%) Title : Compatibility Track Language : English Service kind : Complete Main Default : No Forced : No Audio #3 ID : 4 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 41 min Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : -83 ms Stream size : 222 MiB (1%) Title : Commentary by director/co-writer Ryan Coogler, co-writer Joe Robert Cole, and cinematographer Autumn Durald Arkapaw Language : English Service kind : Complete Main Default : No Forced : No Text #1 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 37 min Bit rate : 45 b/s Frame rate : 0.195 FPS Count of elements : 1835 Stream size : 52.0 KiB (0%) Language : English Default : No Forced : No Text #2 ID : 6 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 38 min Bit rate : 57 b/s Frame rate : 0.255 FPS Count of elements : 2427 Stream size : 66.3 KiB (0%) Title : SDH Language : English Default : No Forced : No Text #3 ID : 7 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 123 b/s Frame rate : 0.355 FPS Count of elements : 3436 Stream size : 145 KiB (0%) Title : Commentary by director/co-writer Ryan Coogler, co-writer Joe Robert Cole, and cinematographer Autumn Durald Arkapaw Language : English Default : No Forced : No Text #4 ID : 8 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 42 b/s Frame rate : 0.183 FPS Count of elements : 1769 Stream size : 50.7 KiB (0%) Language : Czech Default : No Forced : No Text #5 ID : 9 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 39 b/s Frame rate : 0.120 FPS Count of elements : 1158 Stream size : 47.1 KiB (0%) Language : Danish Default : No Forced : No Text #6 ID : 10 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 41 b/s Frame rate : 0.169 FPS Count of elements : 1635 Stream size : 48.9 KiB (0%) Language : German Default : No Forced : No Text #7 ID : 11 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 53 b/s Frame rate : 0.189 FPS Count of elements : 1825 Stream size : 63.6 KiB (0%) Title : SDH Language : German Default : No Forced : No Text #8 ID : 12 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 76 b/s Frame rate : 0.183 FPS Count of elements : 1766 Stream size : 90.4 KiB (0%) Language : Greek Default : No Forced : No Text #9 ID : 13 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 45 b/s Frame rate : 0.180 FPS Count of elements : 1739 Stream size : 53.4 KiB (0%) Title : Latin American Language : Spanish (Latin America) Default : No Forced : No Text #10 ID : 14 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 50 b/s Frame rate : 0.190 FPS Count of elements : 1834 Stream size : 59.8 KiB (0%) Title : Latin American (SDH) Language : Spanish (Latin America) Default : No Forced : No Text #11 ID : 15 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 42 b/s Frame rate : 0.179 FPS Count of elements : 1732 Stream size : 49.7 KiB (0%) Language : Spanish (ES) Default : No Forced : No Text #12 ID : 16 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 45 b/s Frame rate : 0.182 FPS Count of elements : 1756 Stream size : 54.1 KiB (0%) Language : Finnish Default : No Forced : No Text #13 ID : 17 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 49 b/s Frame rate : 0.184 FPS Count of elements : 1776 Stream size : 58.6 KiB (0%) Title : Canadian Language : French (CA) Default : No Forced : No Text #14 ID : 18 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 64 b/s Frame rate : 0.266 FPS Count of elements : 2571 Stream size : 75.8 KiB (0%) Title : Canadian (SDH) Language : French (CA) Default : No Forced : No Text #15 ID : 19 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 40 b/s Frame rate : 0.171 FPS Count of elements : 1655 Stream size : 47.8 KiB (0%) Language : French (FR) Default : No Forced : No Text #16 ID : 20 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 50 b/s Frame rate : 0.198 FPS Count of elements : 1917 Stream size : 59.8 KiB (0%) Title : SDH Language : French (FR) Default : No Forced : No Text #17 ID : 21 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 42 b/s Frame rate : 0.182 FPS Count of elements : 1758 Stream size : 50.2 KiB (0%) Language : Hungarian Default : No Forced : No Text #18 ID : 22 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 45 b/s Frame rate : 0.182 FPS Count of elements : 1760 Stream size : 53.6 KiB (0%) Language : Icelandic Default : No Forced : No Text #19 ID : 23 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 40 b/s Frame rate : 0.181 FPS Count of elements : 1747 Stream size : 48.3 KiB (0%) Language : Italian Default : No Forced : No Text #20 ID : 24 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 37 b/s Frame rate : 0.171 FPS Count of elements : 1655 Stream size : 44.1 KiB (0%) Language : Japanese Default : No Forced : No Text #21 ID : 25 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 42 b/s Frame rate : 0.183 FPS Count of elements : 1773 Stream size : 50.4 KiB (0%) Language : Korean Default : No Forced : No Text #22 ID : 26 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 43 b/s Frame rate : 0.161 FPS Count of elements : 1552 Stream size : 51.6 KiB (0%) Language : Dutch Default : No Forced : No Text #23 ID : 27 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 42 b/s Frame rate : 0.183 FPS Count of elements : 1768 Stream size : 49.7 KiB (0%) Language : Norwegian Default : No Forced : No Text #24 ID : 28 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 38 b/s Frame rate : 0.183 FPS Count of elements : 1768 Stream size : 45.7 KiB (0%) Language : Polish Default : No Forced : No Text #25 ID : 29 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 45 b/s Frame rate : 0.183 FPS Count of elements : 1767 Stream size : 53.1 KiB (0%) Title : Brazilian Language : Portuguese (BR) Default : No Forced : No Text #26 ID : 30 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 33 min Bit rate : 53 b/s Frame rate : 0.237 FPS Count of elements : 2192 Stream size : 60.8 KiB (0%) Title : Brazilian (SDH) Language : Portuguese (BR) Default : No Forced : No Text #27 ID : 31 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 44 b/s Frame rate : 0.182 FPS Count of elements : 1754 Stream size : 52.9 KiB (0%) Language : Portuguese (PT) Default : No Forced : No Text #28 ID : 32 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 44 b/s Frame rate : 0.182 FPS Count of elements : 1761 Stream size : 52.9 KiB (0%) Language : Romanian Default : No Forced : No Text #29 ID : 33 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 39 b/s Frame rate : 0.183 FPS Count of elements : 1765 Stream size : 47.1 KiB (0%) Language : Slovak Default : No Forced : No Text #30 ID : 34 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 41 b/s Frame rate : 0.137 FPS Count of elements : 1323 Stream size : 48.5 KiB (0%) Language : Swedish Default : No Forced : No Text #31 ID : 35 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 44 b/s Frame rate : 0.183 FPS Count of elements : 1769 Stream size : 52.7 KiB (0%) Language : Turkish Default : No Forced : No Text #32 ID : 36 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 35 b/s Frame rate : 0.184 FPS Count of elements : 1775 Stream size : 41.6 KiB (0%) Title : Hong Kong Language : Chinese (HK) Default : No Forced : No Text #33 ID : 37 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 42 b/s Frame rate : 0.184 FPS Count of elements : 1774 Stream size : 50.1 KiB (0%) Title : Simplified Language : Chinese (Simplied) Default : No Forced : No Text #34 ID : 38 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 41 min Bit rate : 34 b/s Frame rate : 0.184 FPS Count of elements : 1782 Stream size : 40.7 KiB (0%) Title : Traditional Language : Chinese (Traditional) Default : No Forced : No Menu 00:11:47.583 : en:Scene 1 00:29:52.417 : en:Scene 2 00:39:54.186 : en:Scene 3 00:53:09.314 : en:Scene 4 01:02:33.170 : en:Scene 5 01:15:06.423 : en:Scene 6 01:28:20.926 : en:Scene 7 01:44:45.202 : en:Scene 8 01:58:03.584 : en:Scene 9 02:04:36.185 : en:Scene 10 02:24:00.891 : en:Scene 11 02:28:56.061 : en:Credits 02:31:27.671 : en:Post-Credits Scene Edited February 4, 2023 by Utini 1
Utini 14 Posted March 7, 2023 Posted March 7, 2023 On 2/21/2023 at 3:46 AM, Luke said: Have your questions been answered? Yes but please finally update the LG TV app to fix the issues also mentioned in the link below. The app / issue hasn't been updated since last year. I can't even properly play 1080p content without constant freezes.
Luke 42234 Posted July 7, 2023 Posted July 7, 2023 HI, please try the newly released Emby for LG 1.0.39 and let us know how things compare. Thanks !
AtlasRedux 2 Posted July 7, 2023 Author Posted July 7, 2023 31 minutes ago, Luke said: HI, please try the newly released Emby for LG 1.0.39 and let us know how things compare. Thanks ! Don't have the C1 anymore, so I can't check that, but I assume if it works on my new C2 65" it should work on the C1. Tried a variation of formats on movies, and all seem to work now
