justinrh 267 Posted January 28, 2023 Posted January 28, 2023 (edited) I have a 5.1 audio system. If I tell ATV, in Playback settings > Audio, to convert unsupported audio to Digital Dolby, and my file has AAC 5.1, stats tells me it is delivering 7.1 channel audio to my system and shows a conversion reason of "Audio channels over limit". This does not compute with me. Can someone explain? ON_ffmpeg-remux-d31f3526-3dc6-4937-aac1-366572ff862d_1.txt App log sent @ 11:44am ET, user home. Edited January 28, 2023 by justinrh
Happy2Play 9812 Posted January 28, 2023 Posted January 28, 2023 Devs will have to comment but the log shows aac 5.1 conversion to ac3 5.1. &aac-audiochannels=2 &TranscodeReasons=AudioChannelsNotSupported Log shows conversion to 5.1 -c:v:0 copy -bsf:v:0 h264_mp4toannexb -c:a:0 ac3 -ab:a:0 256140 -ar:a:0 48000 -ac:a:0 6 10:42:22.311 Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1, fltp, 256 kb/s (default)
justinrh 267 Posted January 28, 2023 Author Posted January 28, 2023 Okaaayyy. What is Emby stats telling me? 7.1 channels shouldn't even be in the equation, but it is. Is Emby saying it needs to send 7.1 or that it thinks I have 7.1? Why the overlimit error?
justinrh 267 Posted January 29, 2023 Author Posted January 29, 2023 1 hour ago, Happy2Play said: aac-audiochannels=2 Actually, Happy, doesn't it show that Emby thinks it is stereo source? Oh, I get the error now: 2 + 5.1 = 7.1!
Happy2Play 9812 Posted January 29, 2023 Posted January 29, 2023 3 minutes ago, justinrh said: Actually, Happy, doesn't it show that Emby thinks it is stereo source? Oh, I get the error now: 2 + 5.1 = 7.1! No that is client playback protocol saying it can only handle 2 channel aac. Since your track is more than 2 channels you will get "Audio channels over limit". &aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=2&mp3-audiochannels=8 I guess the question is why your system shows limited to 2 channel aac as I have seen others logs showing 8 but can only guess as I am not a Android user but may have to do with client settings. 1
Luke 42245 Posted January 29, 2023 Posted January 29, 2023 It's not an error. One reason could be if you enabled the audio down mix option in the app.
Happy2Play 9812 Posted January 29, 2023 Posted January 29, 2023 6 minutes ago, Luke said: It's not an error. One reason could be if you enabled the audio down mix option in the app. Confused on where this comes from though as there is nothing in the ffmpeg log for this. Is the client changing the converted ac3 5.1 also?
Solution ebr 16337 Posted January 29, 2023 Solution Posted January 29, 2023 Hi. That's telling you the reason it is converting which is this: 14 hours ago, justinrh said: If I tell ATV, in Playback settings > Audio, to convert unsupported audio to Digital Dolby Most devices will not accept multi-channel AAC so the app is doing what you asked it to do. As for why it says it is delivering 7.1, I'm not sure, That information is coming from the transcoding information the app gets from the server so something must be off there. 1
justinrh 267 Posted February 1, 2023 Author Posted February 1, 2023 On 1/28/2023 at 6:45 PM, Luke said: if you enabled the audio down mix option in the app. @Luke I can't have down mix set and convert unsupported at the same time. So, if you can put this bug on your board, it would be appreciated.
Luke 42245 Posted February 1, 2023 Posted February 1, 2023 7 minutes ago, justinrh said: @Luke I can't have down mix set and convert unsupported at the same time. So, if you can put this bug on your board, it would be appreciated. Put what back on the board? Didn't ebr answer your question?
justinrh 267 Posted February 1, 2023 Author Posted February 1, 2023 You mean you took it off the board once already? LOL The errant information needs to be resolved -> Emby says it is sending 7.1 audio. ebr explained why Emby is transcoding, but he could not explain the above.
Happy2Play 9812 Posted February 1, 2023 Posted February 1, 2023 On 1/29/2023 at 5:36 AM, ebr said: As for why it says it is delivering 7.1, I'm not sure, That information is coming from the transcoding information the app gets from the server so something must be off there. Yes the 7.1 is a mystery. But do not know what 63 represents here.
