markand 9 Posted January 28, 2023 Posted January 28, 2023 I've been running Emby on my QNAP TVS-872XT for the past 3 years and it's been great. Unfortunately it died and I just replaced it with a TS-464, which got great reviews. I have it with 16GB of Memory taken from the old unit. After migrating the drives over and re-installing Emby I began doing some tests. Playing a single video in my browser causes server CPU to be about 97%. Hardware acceleration is on. Note the Emby process is using 88% CPU . I also have Plex set up to point to the same libraries and playing the same video yields CPU utilization of 12%. Note Plex is using 0.14% even while playing back. Any idea what's wrong? Emby used to use barely any CPU on the old config.
GrimReaper 4895 Posted January 28, 2023 Posted January 28, 2023 Not familiar with QNAPs, but could you post hardware detection log and ffmpeg log for that high-CPU playback, as I suspect subtitles?
markand 9 Posted January 28, 2023 Author Posted January 28, 2023 One update of good news. For some reason, I thought to try playing back the video using my iPhone. Then the CPU usage is even less that Plex! I also played from my Android TV and the CPU usage was also low. So it seems like playing in Safari doesn't use hardware acceleration but on the devices it works. I'm not sure how it worked with the old NAS as I never use the browser, but did for this test. Note: Emby server CPU isn't visible but is around 0.13%.
GrimReaper 4895 Posted January 28, 2023 Posted January 28, 2023 (edited) 5 minutes ago, markand said: So it seems like playing in Safari doesn't use hardware acceleration but on the devices it works. Without logs noone can tell you exactly is transcoding being hardware accelerated or not, as those items might just have been DirectPlayed in which case it means nothing in respect to your original query. Edited January 28, 2023 by GrimReaper Typo 1
markand 9 Posted January 28, 2023 Author Posted January 28, 2023 Attached are the logs after a reboot. Interestingly, I do not see any ffmpeg logs being produced when playing from my phone or TV. MarkAnd_Emby_Logs_1_28_2023.zip
Happy2Play 9811 Posted January 28, 2023 Posted January 28, 2023 7 minutes ago, markand said: Attached are the logs after a reboot. Interestingly, I do not see any ffmpeg logs being produced when playing from my phone or TV. MarkAnd_Emby_Logs_1_28_2023.zip 116.44 kB · 1 download That suggest direct play. As for Safari &TranscodeReasons=ContainerNotSupported,DirectPlayError Hard to say why there was a direct play error though. Do you have Emby Premiere? What is your Transcode setting as it appears HWA is disabled? But do not know this device. >>>>>> FindVideoEncoder - MediaType: h264, UseHardwareCodecs: True, HWA-Mode: Disabled Info Checking: 'x264 Software Encoder' Info Check successful - selecting 'x264 Software Encoder' >>>>>> FindVideoDecoder - MediaType: hevc, UseHardwareCodecs: True, HWA-Mode: Disabled Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' 1
GrimReaper 4895 Posted January 28, 2023 Posted January 28, 2023 (edited) 13 minutes ago, markand said: Interestingly, I do not see any ffmpeg logs being produced when playing from my phone or TV. Because those items are DirectPlaying. Do you have HA disabled in your Settings>Transcoding? >>>>>> FindVideoEncoder - MediaType: h264, UseHardwareCodecs: True, HWA-Mode: Disabled >>>>>> FindVideoDecoder - MediaType: hevc, UseHardwareCodecs: True, HWA-Mode: Disabled As your UHD graphics is visible to the system: "VideoDecoders":{"1: VAAPI JasperLake UHD Graphics - MPEG-2":{"IsEnabledByDefault":true,"DefaultPriority":60,"VaapiCodecInfo":{"Name":"VAAPI JasperLake UHD Graphics - MPEG-2","Description":"Adapter #0: 'JasperLake UHD Graphics' Id:20065 (Driver: Intel iHD driver for Intel(R) Gen Graphics - 21.2.2 (27b773b2), Vendor: Intel Corporation)","DeviceInfo":{"IsActive":true,"HardwareContextFramework":"VaApi","Capabilities":{"SupportsHwUpload":true,"SupportsHwDownload":true,"SupportsStandaloneDeviceInit":true,"Supports10BitProcessing":true,"SupportsNativeToneMapping":true} Edited January 28, 2023 by GrimReaper Cross-posted. 1
markand 9 Posted January 29, 2023 Author Posted January 29, 2023 (edited) Ok, sorry for the one error that might have caused confusion. HWA was OFF on the run that I sent. It was initially on, so I was toggling it. I've toggled a few times and now have a run where the following is set: >>>>> FindVideoEncoder - MediaType: h264, UseHardwareCodecs: True, HWA-Mode: Automatic Info Checking: 'QuickSync JasperLake UHD Graphics - H.264 (AVC)' Info Check successful - selecting 'QuickSync JasperLake UHD Graphics - H.264 (AVC)' >>>>>> FindVideoDecoder - MediaType: hevc, UseHardwareCodecs: True, HWA-Mode: Automatic Info Checking: 'VAAPI JasperLake UHD Graphics - H.265 (HEVC)' Info Check successful - selecting 'VAAPI JasperLake UHD Graphics - H.265 (HEVC)' Sorry for the confusion! However, I'm still getting the same high CPU usage. Attached is a new log file. Btw, subtitles are OFF. Oh, and THANK YOU all for your help! ffmpeg-transcode-14133008-9c31-4b36-9ec8-01f50c5854cb_1.txt Edited January 29, 2023 by markand
GrimReaper 4895 Posted January 29, 2023 Posted January 29, 2023 Your QSV HWA is failing: 09:58:48.429 Stream mapping: 09:58:48.429 Stream #0:0 (hevc) -> hwmap:default (graph 0) 09:58:48.429 vpp_qsv:default (graph 0) -> Stream #0:0 (h264_qsv) 09:58:48.429 Stream #0:1 -> #0:1 (opus (native) -> mp3 (libmp3lame)) 09:58:48.429 Press [q] to stop, [?] for help 09:58:48.462 [vpp_qsv@f2 @ 0x7f8cf86ef7c0] Failed to create a qsvvpp: invalid video parameters (-15) 09:58:48.462 [vpp_qsv@f2 @ 0x7f8cf86ef7c0] Failed to configure output pad on vpp_qsv@f2 *** Error in `/share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg': munmap_chunk(): invalid pointer: 0x00007f8cf870dd40 *** so it's falling back to software: Info Previous transcoding attempt failed. Falling back to software transcoding. >>>>>> FindVideoEncoder - MediaType: h264, UseHardwareCodecs: False, HWA-Mode: Automatic Info Checking: 'x264 Software Encoder' Info Check successful - selecting 'x264 Software Encoder' >>>>>> FindVideoDecoder - MediaType: hevc, UseHardwareCodecs: False, HWA-Mode: Automatic Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' >>>>>> Processing Plan Name CanDoInHW WillDoInHW Reason Automatic software decoder >> False False Software Codec VideoInput >> False False Not a hardware decoder ColorConversion >> False False VideoOutput >> False False Not a hardware encoder x264 Software Encoder >> False False Software Codec >>>>>> Video Processing Steps for [0:0]: H.265 (HEVC) Step HW-Context Format SW-Format Size Next HEVC >> - yuv420p10 yuv420p10 1280x960 >> format format >> - yuv420p yuv420p 1280x960 >> resulting in high CPU usage. @softworkz
markand 9 Posted January 29, 2023 Author Posted January 29, 2023 So is that something for Luke & Co to look into? Or something I need to do? Or could it be related to QNAP issue? Thanks for tracking that down! Mark
GrimReaper 4895 Posted January 29, 2023 Posted January 29, 2023 I'd wait for Softworkz to comment. In the meantime, you can try setting VAAPI for AVC Encoder under Settings>Transcoding>Advanced and see how does that compare.
markand 9 Posted January 29, 2023 Author Posted January 29, 2023 Interesting. So I went to Transcoding->Advanced and VAAPI was checked for the H.264 (AVC) section. However, for Preferred Hardware Encoders, there was only the QuickSync listed and it was checked. When I unchecked it, the CPU usage was a bit lower - like 72% instead of 95%, but that is an improvement. Here are the settings. Note: Not sure whey QS is off for MPG-2.
Luke 42239 Posted January 29, 2023 Posted January 29, 2023 There will be QuickSync improvements in the upcoming 4.8 server release that should help with this.
markand 9 Posted January 29, 2023 Author Posted January 29, 2023 Super! As I said, it doesn't really affect me much as it's only happening in the browser and that's not how I typically watch. I was just testing out the new NAS and wanted to make sure it was ok. 1
Luke 42239 Posted February 21, 2023 Posted February 21, 2023 Great, thanks. If you're able to try the 4.8 beta server, please let us know how you get on.
markand 9 Posted February 21, 2023 Author Posted February 21, 2023 Happy to try. If I run into problems with 4.8, can I go back to the previous version?
Luke 42239 Posted February 21, 2023 Posted February 21, 2023 4 hours ago, markand said: Happy to try. If I run into problems with 4.8, can I go back to the previous version? Unfortunately no, that's not safe. If you want to roll back then it needs to be a fresh install. Sorry, I know that might make it difficult to jump in, which I understand.
