yanksno1 1 Posted January 29, 2023 Author Posted January 29, 2023 Nope. Wished it worked more like Plex in that regard for finding the server automatically. Decided to go back to Plex for now, there was another thing I didn't quite like about it. If Emby fixes it, I might revisit it later again.
rbjtech 5344 Posted January 30, 2023 Posted January 30, 2023 14 hours ago, yanksno1 said: Nope. Wished it worked more like Plex in that regard for finding the server automatically. Decided to go back to Plex for now, there was another thing I didn't quite like about it. If Emby fixes it, I might revisit it later again. As explained in the PM - the issue was that your client devices were on a 192 network while your docker emby server was on a 172 network. Unless there is a network docker passthough / routing / fw opened up between them - then it's never going to 'find' the emby server (manually) or even less chance of automatically finding them as UDP discovery is local lan only - by design. Plex holds all your user info (and all your media info..) on it's cloud - so yes, that is naturally more 'discoverable' - as long as you have internet access obviously.
ebr 16337 Posted January 30, 2023 Posted January 30, 2023 2 hours ago, rbjtech said: Plex holds all your user info Actually, they own all your users as they are their users, not yours.
Luke 42245 Posted May 1, 2023 Posted May 1, 2023 Did you try setting your docker container to host networking mode?
