Gecko 71 Posted January 25, 2023 Posted January 25, 2023 If Emby says it reduced bitrate due to quality setting, I would first look into that before changing any cables. In one of your picture, Stats for nerds says that Emby sends video chunks through HLS @40mbps, seems like a manual bitrate limitation to me! Check in the dashboard that the Roku Client is connected locally (address is 192.168.X.X) So that Internet limitation does not kick in Check in the settings of Emby client that you set the bitrate to Auto or something like 4K 140Mbps, well beyond your MP4 bitrate. 1
rbjtech 5335 Posted January 25, 2023 Posted January 25, 2023 4 minutes ago, Gecko said: If Emby says it reduced bitrate due to quality setting, I would first look into that before changing any cables. In one of your picture, Stats for nerds says that Emby sends video chunks through HLS @40mbps, seems like a manual bitrate limitation to me! Check in the dashboard that the Roku Client is connected locally (address is 192.168.X.X) So that Internet limitation does not kick in Check in the settings of Emby client that you set the bitrate to Auto or something like 4K 140Mbps, well beyond your MP4 bitrate. Possibly (I think the OP has this set to Auto ?) - but it's the pic below that is confirming the Roku thinks it's connected to SDR display (the Balun). The Balun spec clearly says it supports all forms of HDR and looks to be a suitable - but until the Roku (the emby client) says it's supports HDR 9and direct play) - it's going to transcode. 2
Soundchasr 19 Posted January 25, 2023 Author Posted January 25, 2023 @Gecko That (reduced quality) was after I messed with the settings - can't remember where I was in the process. That's not how it was originally when I was having the problem.
rbjtech 5335 Posted January 25, 2023 Posted January 25, 2023 (edited) I wouldn't have thought this was required - but maybe you need to force the EDID on the Balun to 4K/HDR ? - I would suggest 1100 (let the projector do the scaling). Edited January 25, 2023 by rbjtech 1
Soundchasr 19 Posted January 25, 2023 Author Posted January 25, 2023 @rbjtech Looks like the EDID settings are on the projector side up in the ceiling. Gotta find a big ladder. 1 1
rbjtech 5335 Posted January 25, 2023 Posted January 25, 2023 4 minutes ago, Soundchasr said: @rbjtech Looks like the EDID settings are on the projector side up in the ceiling. Gotta find a big ladder. Ah - so these settings are not on each end of the Balun ? If no - then you possibly need to swap the Baluns - as it's the Roku that needs the EDID, not the Projector ..
Soundchasr 19 Posted January 25, 2023 Author Posted January 25, 2023 @rbjtech Correct. Only on the projector side. I'm going to try to get someone to help me isolate the Baluns out of the equation. 1
Gecko 71 Posted January 25, 2023 Posted January 25, 2023 (edited) 29 minutes ago, rbjtech said: ... but until the Roku (the emby client) says it's supports HDR 9and direct play) - it's going to transcode. You're right, I didn't know that HDR could impact the decision to start a transcode session. I just tested on the webapp and indeed, an all compatible HDR file is transcoded while a non HDR Direct Play. That's good to know, thanks ! Edited January 25, 2023 by Gecko
