MichkeIV 0 Posted January 24, 2023 Posted January 24, 2023 hello there, Yesterday, once again, i started to watch a movie and every 5 minutes the playback was very slow. i try to ad a log in here. embyserver-63810115200.txt
MichkeIV 0 Posted January 24, 2023 Author Posted January 24, 2023 i have logs, but only for streams i'he made earlier that day, but no ffmpeg logs from movie time....
MichkeIV 0 Posted January 25, 2023 Author Posted January 25, 2023 okay, yesterday i was maying a movie atmos movie 1080p webdl, with subtitels, no problem around 19h30 in the evening past 22h i played a serie simple .mkv, 235mb each episode, with english subs, and then it happens again: faltering image... please can you help me??? embyserver-63810201600.txt
ebr 16337 Posted January 25, 2023 Posted January 25, 2023 Hi. This was on your phone? Client=Emby for Android&X-Emby-Device-Name=Galaxy A71 The item was direct playing so it may have simply been a network limitation.
MichkeIV 0 Posted January 25, 2023 Author Posted January 25, 2023 Hello again, No can you check later in the log. I have a connection of 900mb cabled. So no internet limitation. I see errors in the logs but I dont understand them
MichkeIV 0 Posted January 25, 2023 Author Posted January 25, 2023 2023-01-24 22:34:10.589 Error HttpClient: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>718</errorCode><errorDescription>ConflictInMappingEntry</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope> 2023-01-24 22:34:10.600 Error HttpClient: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>606</errorCode><errorDescription>Action not authorized</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope> 2023-01-24 22:34:10.601 Error PortMapper: Error in DeletePortMap *** Error Report ***
ebr 16337 Posted January 25, 2023 Posted January 25, 2023 2 hours ago, MichkeIV said: 2023-01-24 22:34:10.589 Error HttpClient: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>718</errorCode><errorDescription>ConflictInMappingEntry</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope> 2023-01-24 22:34:10.600 Error HttpClient: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>606</errorCode><errorDescription>Action not authorized</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope> 2023-01-24 22:34:10.601 Error PortMapper: Error in DeletePortMap *** Error Report *** Those are unrelated but you should turn off the automatic port mapping feature in the server to eliminate these from your log.
ebr 16337 Posted January 25, 2023 Posted January 25, 2023 2 hours ago, MichkeIV said: No can you check later in the log. Hi. Exactly when and what did you play?
