Lazarus_Long 80 Posted January 24, 2023 Posted January 24, 2023 Not sure if this is a bug or just by design...if I have a collection with 6 movies in it, however 2 are filtered from a user via restrictions, it appears that the box set image still shows the number of discs are 6 (instead of 4). I know there are other views that don't show the disc count which is good, but is it possible to either have the disc count be accurate (or remove) ? Thanks.
GrimReaper 4851 Posted January 24, 2023 Posted January 24, 2023 Adjust desired BoxSet treatment in Cover Art plugin settings.
Lazarus_Long 80 Posted January 24, 2023 Author Posted January 24, 2023 12 minutes ago, GrimReaper said: Adjust desired BoxSet treatment in Cover Art plugin settings. Thanks, I’ll mess around with the options and see what I like better. Doesn’t look like any of the ones that show the discs counts properly though. On another quick question…I know Emby uses TheMovieDB for its collection source. Is there a way to see the collections that are out in TMDB that it’s pulling from? I’d love to auto-create a few more but hoping I could use one from TMDB if there’s one out there.
GrimReaper 4851 Posted January 24, 2023 Posted January 24, 2023 Just now, swallman said: Doesn’t look like any of the ones that show the discs counts properly though. Treatment is applied per image once, not per-user, so disc count will always be same according number of collection items (or max. 6 if more items present, IIRC). 2 minutes ago, swallman said: On another quick question…I know Emby uses TheMovieDB for its collection source. Is there a way to see the collections that are out in TMDB that it’s pulling from? I’d love to auto-create a few more but hoping I could use one from TMDB if there’s one out there. Any item that is in a collection will have section "Part of ...... Collection" on its TMDB site, scroll down. 1
Happy2Play 9800 Posted January 24, 2023 Posted January 24, 2023 24 minutes ago, swallman said: Not sure if this is a bug or just by design...if I have a collection with 6 movies in it, however 2 are filtered from a user via restrictions, it appears that the box set image still shows the number of discs are 6 (instead of 4). I know there are other views that don't show the disc count which is good, but is it possible to either have the disc count be accurate (or remove) ? Thanks. You can't as there is only one image (global) for the item no matter the restrictions. You see the same issue with Library/Genre dynamic images as restrictions do not apply to this single image. 1
