sonofamort 2 Posted January 22, 2023 Posted January 22, 2023 Since migrating Emby to my Synology NAS I have not been able to get any M3U links to work. They work fine on the Emby instance I have running on my Windows server, but when I add them in the Synology instance they do not load. I know this is likely just a simple config issue and would appreciate any guidance.
sonofamort 2 Posted January 22, 2023 Author Posted January 22, 2023 It just occurred to me that this could be the result of Emby not having outbound internet access via the NAS, but I don't think that's the issue since Emby is able to fetch metadata from IMDB, ANIDB, subtitles, and other external resources.
Luke 42242 Posted January 22, 2023 Posted January 22, 2023 Hi there, what exactly happens when you try?
sonofamort 2 Posted January 22, 2023 Author Posted January 22, 2023 Nothing…the channels don’t load at all but there’s no error either.
Luke 42242 Posted January 23, 2023 Posted January 23, 2023 Please try running the refresh guide scheduled task. Then if the problem persists please attach the emby server log. How to Report a Problem Thanks.
