zcq100 7 Posted January 21, 2023 Posted January 21, 2023 Synology DSM 920 I deploy emby-server on docker Quote docker run -d \ --name emby-prim2\ --device=/dev/dri \ -p 8092:8092 \ -p 8096:8096 \ -v /volume1/docker/emby/config/:/config \ -v /volume2/Movies_1/:/Movies_1 \ -v /volume3/Movies_2/:/Movies_2 \ -v /volume2/TVs_1/:/TVs_1 \ -v /volume3/TVs_2/:/TVs_2 \ -v /volume2/Downloads/:/downloads \ -e UID=1026 \ -e GID=100 \ -e GIDLIST=100,101 \ -e http_proxy='http://ds920:7890' \ -e https_proxy='http://ds920:7890' \ -e no_proxy='localhost,127.0.0.1' \ emby/embyserver:latest Emby Server can't find hardware. Quote user@DS920:$ sudo docker exec -it emby-prim2 ash / # ls -al /dev/dri total 0 drwxr-xr-x 2 root root 80 Jan 21 04:41 . drwxr-xr-x 6 root root 360 Jan 21 04:41 .. crw------- 1 root root 226, 0 Jan 21 04:41 card0 crw-rw---- 1 root 937 226, 128 Jan 21 04:41 renderD128 / # / # cat /proc/cpuinfo processor : 0 vendor_id : GenuineIntel cpu family : 6 model : 122 model name : Intel(R) Celeron(R) J4125 CPU @ 2.00GHz stepping : 8 microcode : 0x16 cpu MHz : 2001.000 cache size : 4096 KB physical id : 0 siblings : 4 core id : 0 cpu cores : 4 apicid : 0 initial apicid : 0 fpu : yes fpu_exception : yes cpuid level : 24 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave rdrand lahf_lm 3dnowprefetch intel_pt ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust smep erms mpx rdseed smap clflushopt sha_ni xsaveopt xsavec xgetbv1 dtherm ida arat pln pts md_clear arch_capabilities ... hardware_detection-63809872891.txt
DonMacaroni 55 Posted January 21, 2023 Posted January 21, 2023 (edited) Nevermind, Emby Docker image includes its own driver, so my suggestion I posted is not necessary. Edited January 21, 2023 by DonMacaroni
Luke 42242 Posted January 22, 2023 Posted January 22, 2023 18 hours ago, zcq100 said: Synology DSM 920 I deploy emby-server on docker Emby Server can't find hardware. hardware_detection-63809872891.txt 134.99 kB · 1 download Hi, as a test, can you try our native Synology package to see how that compares? Thanks !
Solution zcq100 7 Posted February 8, 2023 Author Solution Posted February 8, 2023 I found the problem, I forgot to add the video group id to GIDLIST. After that, emby server can discover the decoder. 1
