Blazejos 8 Posted January 20, 2023 Posted January 20, 2023 Hi @Luke, I'm trying to use both sync plugins, with moderate luck. I have configured Dropbox sync, yet I don't see any "sync" options in my movies, neither on users settings. I am probably missing something, but can't figure out what it is. In Folder Sync plugin, I'm at loss what is a "Path" required in configuration? @cayars Pls advise. Thanks!
Luke 42242 Posted January 23, 2023 Posted January 23, 2023 Hi, try using Download To... in the various context menus. That is the new name for it. Quote In Folder Sync plugin, I'm at loss what is a "Path" required in configuration? Wherever you want the transferred files to be stored.
Blazejos 8 Posted January 23, 2023 Author Posted January 23, 2023 9 hours ago, Luke said: Hi, try using Download To... in the various context menus. That is the new name for it. Nope.. I'm not seeing Dropbox as as destination option in any "Download to". "Wherever you want the transferred files to be stored." That doesn't help much.. Folder Sync name suggest I can point out a folder on my NAS (Emby data source) and destination - I'm assuming this is a location of, say, Google Drive files on my NAS? How do I trigger the sync on specific files?
Blazejos 8 Posted January 23, 2023 Author Posted January 23, 2023 On 1/23/2023 at 9:07 AM, Blazejos said: Nope.. I'm not seeing Dropbox as as destination option in any "Download to". "Wherever you want the transferred files to be stored." That doesn't help much.. Folder Sync name suggest I can point out a folder on my NAS (Emby data source) and destination - I'm assuming this is a location of, say, Google Drive files on my NAS? How do I trigger the sync on specific files? I have used for a Path: /volume1/homes/Blazejos/Drive/Drop/emby plugin saved files to: /volume1/@appstore/EmbyServer/volume1/homes/Blazejos/Drive/Drop/emby Dropbox sync is no show. It seems to me both sync plugin's should be reworked to the emby server level of usability or pulled off the catalogue.. @cayars
Carlo 4561 Posted March 13, 2023 Posted March 13, 2023 I'm in favor of pulling cloud sync plugins as I think it's better to use Rclone which is feature rich in control and supports a ton of providers. Rclone runs on just about every platform as well. It's a very versatile way to access cloud media file that can be used with Emby in many different ways.
Blazejos 8 Posted March 17, 2023 Author Posted March 17, 2023 @Luke@cayarsI haven't found rclone in plugins catalogue, nor reliable install manual for my synology, so I gave this up. It's not that big of a deal.
