Luke 42243 Posted June 2, 2025 Posted June 2, 2025 On 5/31/2025 at 10:01 AM, NorthDegree said: Here you go Luke, emby version on shield is 2.1.23g and server version is 4.8.11 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
NorthDegree 10 Posted June 2, 2025 Posted June 2, 2025 I installed “emby for android” , and on first test, it populated the shield Home Screen “play next” and offered a second channel “continue watching” on the shield home screen that is the good news, the bad news, after a few watching tv show tests… the tv shows do not update on the shield Home Screen (in progress or if completely marked as watched)
Luke 42243 Posted June 2, 2025 Posted June 2, 2025 Hi, we’ll look at making it update more frequently. Thanks.
NorthDegree 10 Posted June 2, 2025 Posted June 2, 2025 Quick update, did not have time to test more thoroughly, back at it now and it seems to update but getting strange behavior with default shield launcher, it duplicates and triples the shows on play next (or continue watching channel) so I decided to test on a different launcher (projectivity) and default watch next is wonky but the emby continue watching channel works pretty much perfectly. ON a side note: is “emby for android” app you recommend for android tv ? (Not the emby for android tv app) 1
