Nastream 5 Posted January 23, 2023 Author Posted January 23, 2023 Thank you TeamB for the update I still have crashes on android but I think it comes from kodi 20 and not the addon, I also have a lot of error on windows example : 2023-01-23 21:34:21.203 T:6136 error <general>: Control 502 in window 10025 has been asked to focus, but it can't 2023-01-23 21:34:21.209 T:19596 error <general>: CImageLoader::DoWork - Direct texture file loading failed for resource://resource.images.weathericons.white/26.png 2023-01-23 21:34:24.103 T:13084 warning <general>: Skin Helper Service --> Exception details: Type: TypeError Value: string indices must be integers Traceback: Traceback (most recent call last): File "C:\Users\Home\AppData\Roaming\Kodi\addons\script.skin.helper.service\resources\lib\listitem_monitor.py", line 375, in set_listitem_details details, self.metadatautils.get_tvdb_details( File "C:\Users\Home\AppData\Roaming\Kodi\addons\script.module.simplecache\lib\simplecache.py", line 304, in decorated result = func(*args, **kwargs) File "C:\Users\Home\AppData\Roaming\Kodi\addons\script.module.metadatautils\lib\metadatautils.py", line 274, in get_tvdb_details result = self.thetvdb.get_series_by_imdb_id(imdbid) File "C:\Users\Home\AppData\Roaming\Kodi\addons\script.module.simplecache\lib\simplecache.py", line 304, in decorated result = func(*args, **kwargs) File "C:\Users\Home\AppData\Roaming\Kodi\addons\script.module.thetvdb\lib\thetvdb.py", line 172, in get_series_by_imdb_id return self.get_series(items[0]["id"]) File "C:\Users\Home\AppData\Roaming\Kodi\addons\script.module.simplecache\lib\simplecache.py", line 304, in decorated result = func(*args, **kwargs) File "C:\Users\Home\AppData\Roaming\Kodi\addons\script.module.thetvdb\lib\thetvdb.py", line 165, in get_series return self._map_series_data(seriesinfo) File "C:\Users\Home\AppData\Roaming\Kodi\addons\script.module.thetvdb\lib\thetvdb.py", line 546, in _map_series_data result["cast.%s.tvdbname" % count] = item["name"] TypeError: string indices must be integers 2023-01-23 21:34:24.103 T:13084 error <general>: Skin Helper Service --> Exception in resources.lib.listitem_monitor ! --> string indices must be integers 2023-01-23 21:35:14.909 T:12364 error <general>: CImageLoader::DoWork - Direct texture file loading failed for resource://resource.images.weathericons.white/26.png 2023-01-23 21:35:18.860 T:6136 info <general>: Skipped 1 duplicate messages.. 2023-01-23 21:35:18.860 T:6136 error <general>: Control 512 in window 10025 has been asked to focus, but it can't 2023-01-23 21:35:23.206 T:4072 info <general>: EmbyCon.resources.lib.functions|INFO|Sending embycon_play_action : {'action': 'play', 'item_id': '2759744', 'auto_resume': '-1', 'force_transcode': False, 'media_source_id': '', 'subtitle_stream_index': None, 'audio_stream_index': None} 2023-01-23 21:35:23.262 T:12596 info <general>: EmbyCon.resources.lib.play_utils|INFO|Received embycon_play_action : {'action': 'play', 'item_id': '2759744', 'auto_resume': '-1', 'force_transcode': False, 'media_source_id': '', 'subtitle_stream_index': None, 'audio_stream_index': None} 2023-01-23 21:35:25.268 T:12596 info <general>: EmbyCon.resources.lib.play_utils|INFO|Play URL: http://***=subrip Playback Type: 1 ListItem Properties: [] 2023-01-23 21:35:25.478 T:6136 info <general>: VideoPlayer::OpenFile: http://***Static=true&PlaySessionId=ac7937b39fd34a738a324e074e8aad98&api_key=c2e0&SubtitleCodec=subrip 2023-01-23 21:35:25.478 T:11028 info <general>: Creating InputStream 2023-01-23 21:35:25.605 T:11028 info <general>: Creating Demuxer 2023-01-23 21:35:25.633 T:6136 info <general>: Loading skin file: C:\Users\Home\AppData\Roaming\Kodi\addons\plugin.video.embycon\resources\skins\default\720p\PlayNextDialog.xml, load type: LOAD_ON_GUI_INIT 2023-01-23 21:35:25.735 T:19224 error <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <class 'TypeError'> Error Contents: unsupported operand type(s) for /: 'NoneType' and 'float' Traceback (most recent call last): File "C:\Users\Home\AppData\Roaming\Kodi\addons\plugin.video.embycon\resources\lib\playnext.py", line 143, in onInit duration = (runtime_ticks / 10000000.0) / 60.0 # convert ticks to minutes TypeError: unsupported operand type(s) for /: 'NoneType' and 'float' -->End of Python script error report<--
TeamB 2440 Posted January 23, 2023 Posted January 23, 2023 59 minutes ago, Nastream said: 2023-01-23 21:35:25.735 T:19224 error <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <class 'TypeError'> Error Contents: unsupported operand type(s) for /: 'NoneType' and 'float' Traceback (most recent call last): File "C:\Users\Home\AppData\Roaming\Kodi\addons\plugin.video.embycon\resources\lib\playnext.py", line 143, in onInit duration = (runtime_ticks / 10000000.0) / 60.0 # convert ticks to minutes TypeError: unsupported operand type(s) for /: 'NoneType' and 'float' -->End of Python script error report<-- This error is weird, I can not reproduce it locally. I think this is due to incomplete data being returned from the server. What Emby Server version are you running? I have added some extra dubug logging to the latest version EmbyCon 1.11.3 Turn OFF Kodi Debug logging Turn ON EmbyCon Debug Logging (under the advanced tab in the EmbyCon add-on settings) Restart Kodi Reproduce the issue and PM me the Kodi Log. Thanks
Nastream 5 Posted January 24, 2023 Author Posted January 24, 2023 hello TeamB, I sent the logs, Thanks
b0mb 36 Posted February 2, 2023 Posted February 2, 2023 Embycon on Shield Pro 2019 with latest Maven Nexus Build running without any problems 1
Nastream 5 Posted March 5, 2023 Author Posted March 5, 2023 problem solved with this version: https://mirrors.kodi.tv/nightlies/android/arm64-v8a/Nexus/kodi-20230301-22153da8-Nexus-arm64-v8a.apk I noticed a bug on the tv series, the "Seen" tick is activated on all series on android ( Ok windows ) Ok for movies. Thanks
TeamB 2440 Posted March 6, 2023 Posted March 6, 2023 7 hours ago, Nastream said: problem solved with this version: https://mirrors.kodi.tv/nightlies/android/arm64-v8a/Nexus/kodi-20230301-22153da8-Nexus-arm64-v8a.apk I noticed a bug on the tv series, the "Seen" tick is activated on all series on android ( Ok windows ) Ok for movies. Thanks unfortunately I dont have an android client to test on so can not reproduce this. what happens if you use a different skin?
Nastream 5 Posted March 6, 2023 Author Posted March 6, 2023 I just checked with another skin and I don't have the problem it's the aura mod skin that is the problem
Nastream 5 Posted March 6, 2023 Author Posted March 6, 2023 (edited) I just did some tests, in version: 1.10.31 it's OK in version 1.11.8 all series are in View mode : Edited March 6, 2023 by Nastream
TeamB 2440 Posted March 7, 2023 Posted March 7, 2023 @Nastream I can not find the "aura mod" skin in the Kodi repo, is it in the official kodi repo? Are the above screen shots both from Kodi 20?
Nastream 5 Posted March 7, 2023 Author Posted March 7, 2023 Skin Aura mod 1.1.9 https://github.com/SerpentDrago/skin.auramod/releases/tag/v1.1.9 Yes both screen are in Kodi 20 the file causing the "problem" is: item_functions.py
TeamB 2440 Posted March 7, 2023 Posted March 7, 2023 (edited) 3 hours ago, Nastream said: Skin Aura mod 1.1.9 https://github.com/SerpentDrago/skin.auramod/releases/tag/v1.1.9 Yes both screen are in Kodi 20 the file causing the "problem" is: item_functions.py un comment this line in the item_functions.py file, restart Kodi and see what if that fixes it item_properties["UnWatchedEpisodes"] = str(item_details.unwatched_episodes) Edited March 7, 2023 by TeamB
Nastream 5 Posted March 7, 2023 Author Posted March 7, 2023 perfect @TeamB it works very well ! Thank you! I hope it will be included in the new version
TeamB 2440 Posted March 7, 2023 Posted March 7, 2023 5 hours ago, Nastream said: perfect @TeamB it works very well ! Thank you! I hope it will be included in the new version yes this fix will be in the next release in a day or so 1
degrashopp 0 Posted March 30, 2023 Posted March 30, 2023 I have the same problem. using kodi on a google tv. Trying to figure out what was wrong with kodi I did a clean install and at first it was working again. But after updating embycon from 1.10.34 to 1.11.10 it was broken again. I get the same errors as mentioned above. On version 1.10.34 all my libraries work fine. The strange thing is that after updating to 1.11.34, 2 of the 3 libraries are working. without issue. 1 library is broken after updating the addon. All settings look the same for this library compared to the other 2. The 2 that work are a series library and a movie library. the one that is not working is a movie library.
TeamB 2440 Posted March 30, 2023 Posted March 30, 2023 (edited) 2 hours ago, degrashopp said: I have the same problem. using kodi on a google tv. Trying to figure out what was wrong with kodi I did a clean install and at first it was working again. But after updating embycon from 1.10.34 to 1.11.10 it was broken again. I get the same errors as mentioned above. On version 1.10.34 all my libraries work fine. The strange thing is that after updating to 1.11.34, 2 of the 3 libraries are working. without issue. 1 library is broken after updating the addon. All settings look the same for this library compared to the other 2. The 2 that work are a series library and a movie library. the one that is not working is a movie library. 1.10.x is for kodi 19 1.11.x is for kodi 20 what version of kodi are you using? i will need a kodi log to investigate any errors. Edited March 30, 2023 by TeamB
degrashopp 0 Posted March 31, 2023 Posted March 31, 2023 (edited) 16 hours ago, TeamB said: 1.10.x is for kodi 19 1.11.x is for kodi 20 what version of kodi are you using? i will need a kodi log to investigate any errors. I'm using kodi 20.1 (latest). I know 1.10.x is for 19 but that one works. I will try to provide some logging soon. Edited March 31, 2023 by degrashopp
degrashopp 0 Posted March 31, 2023 Posted March 31, 2023 (edited) 3 hours ago, degrashopp said: I'm using kodi 20.1 (latest). I know 1.10.x is for 19 but that one works. I will try to provide some logging soon. @TeamBhereby the log https://paste.kodi.tv/sanojevisa.kodi Edited March 31, 2023 by degrashopp
TeamB 2440 Posted April 1, 2023 Posted April 1, 2023 9 hours ago, degrashopp said: @TeamBhereby the log https://paste.kodi.tv/sanojevisa.kodi ok yeah I think I know what is happening here. are you able to turn off Kodi Debug logging and turn on EmbyCon Debug logging (in the EmbyCon addon setting), reproduce PM me the log, this will help a little more and gove me some more contect as to what caused the error.
