sross44 434 Posted January 18, 2023 Posted January 18, 2023 So my parents log in remotely to my server as well as all of my other family, but I’ll use my parents for this specific question. They are set up as separate users but is there a good way to set up Emby on their Shield to switch between the two of them (or select between all the accounts) that they don’t have to type in a password each time? if I log in via connect it’s not that easy to switch users really. If I log in with my setup domain, it requires a password each time. Maybe I’m missing something easy but I’m just trying to figure out what others do here. Hope this makes sense!
Luke 42259 Posted January 19, 2023 Posted January 19, 2023 Hi, only one set of credentials is saved at a time so no, there's no quick way at this time.
sross44 434 Posted January 19, 2023 Author Posted January 19, 2023 30 minutes ago, Luke said: Hi, only one set of credentials is saved at a time so no, there's no quick way at this time. Ahhh that's super disapointing. It'd be great if multiple credentials could be saved. Thanks for the reply on this.
Solution GrimReaper 4916 Posted January 19, 2023 Solution Posted January 19, 2023 6 minutes ago, sross44 said: It'd be great if multiple credentials could be saved. You might wanna lend your support here:
sross44 434 Posted January 19, 2023 Author Posted January 19, 2023 Thanks @GrimReaper. I did just that. Most appreciated. 1
rbjtech 5345 Posted January 19, 2023 Posted January 19, 2023 (edited) I haven't tried this myself, but would the actual client os user profile (FireTV profiles etc) have separate login credentials for it's apps ? Edited January 19, 2023 by rbjtech
sross44 434 Posted January 19, 2023 Author Posted January 19, 2023 39 minutes ago, rbjtech said: I haven't tried this myself, but would the actual client os user profile (FireTV profiles etc) have separate login credentials for it's apps ? If the client apps could save multiple logins at once, this would solve all of the needs. So in either scenario, if someone logs in via connect or their password, the app stores the password until they are logged in again. You could obviously disable this feature on the server side if you wanted to, but ideally this was just an app feature on the client side. At least my thoughts on that.
rbjtech 5345 Posted January 19, 2023 Posted January 19, 2023 8 minutes ago, sross44 said: If the client apps could save multiple logins at once, this would solve all of the needs. So in either scenario, if someone logs in via connect or their password, the app stores the password until they are logged in again. You could obviously disable this feature on the server side if you wanted to, but ideally this was just an app feature on the client side. At least my thoughts on that. No I agree with you - I'm just suggesting that for FireTV (other clients may have this too) - you actually have 'FireTV Profiles' - and while I haven't tested this - I'm presuming you could save multiple emby users passwords as they have their own profile. It's a workaround, as I can't see all the emby clients getting the necessary changes any time soon ...
sross44 434 Posted January 19, 2023 Author Posted January 19, 2023 4 minutes ago, rbjtech said: No I agree with you - I'm just suggesting that for FireTV (other clients may have this too) - you actually have 'FireTV Profiles' - and while I haven't tested this - I'm presuming you could save multiple emby users passwords as they have their own profile. It's a workaround, as I can't see all the emby clients getting the necessary changes any time soon ... That's an interesting thought. I'd have to check, but of course the majority of these instances are Shield TV (no profiles) and Rokus (no profiles). It's funny to me that I didn't realize all of this before because it's a pretty important feature that multiple people should be able to easily log in to their profile regardless of location.
Neminem 1627 Posted January 19, 2023 Posted January 19, 2023 Hmm setup an vpn tunnel between you folks and you. Have them connect though that, then they will be treated like lan users. And let them login with out password on lan
