lightsout 156 Posted January 17, 2023 Posted January 17, 2023 I went through some of the threads about the UHD 770, which seems to have amazing transcode performance. I saw the UHD 630 mentioned, but haven't found anyone posting actual results. Anyone running one, I am specifically interested in 4k HDR tone-mapped to 1080p SDR.
Q-Droid 1011 Posted January 17, 2023 Posted January 17, 2023 Search for UHD630 and you'll find plenty of hits. That said it can typically handle 3-4 4k HDR to 1080p SDR transcoding streams. Like everything it depends on what you're doing. Burning in subtitles and/or high bitrate output will affect that and possibly reduce it. I usually get that level of performance from an i3-8100. 1
RanmaCanada 502 Posted January 18, 2023 Posted January 18, 2023 I posted plenty about my old laptop. It can handle 3 4k transcodes to 1080p sdr before it throws up, which is why I upgraded. It is seriously underpowered for 4k transcodes and you want a 700 series iGPU or a nice Intel Arc graphics card.
lightsout 156 Posted January 18, 2023 Author Posted January 18, 2023 14 hours ago, RanmaCanada said: I posted plenty about my old laptop. It can handle 3 4k transcodes to 1080p sdr before it throws up, which is why I upgraded. It is seriously underpowered for 4k transcodes and you want a 700 series iGPU or a nice Intel Arc graphics card. Thanks, this is just for a home situation so that is plenty of performance.
