the_bakken 0 Posted January 17, 2023 Posted January 17, 2023 I have run into a very obscure issue. I have a computer with a connected Logitech Steering Wheel and pedals. When accessing the webapp, it is capturing the input from the clutch pedal and interpreting it as a command to scroll. So once I click on anything, for example a letter to scroll to in my library, it will scroll all the way to the bottom of the page. if the clutch pedal is depressed all the way down it will scroll to the top of the page. The only way to use the webapp is to hold the pedal half way down during any interaction. Is there any setting that I can set to make the webapp stop listening to controller inputs? This is the only time I have ever encountered this type of behavior using any websites or apps in a browser.
the_bakken 0 Posted January 17, 2023 Author Posted January 17, 2023 It looks like the issue is in the gamepadtokey.js module that gets loaded. removing that module eliminates this problem. After searching this forum i see that it is not as obscure of a problem as I thought. If a setting could be added to prevent the loading of that module it would solve the problem for everyone that is encountering it.
Solution Luke 42239 Posted January 17, 2023 Solution Posted January 17, 2023 HI, yes, more options to control this are planned for future updates. Thanks.
Modex 0 Posted February 29, 2024 Posted February 29, 2024 I am also having this problem with Thrustmaster pedals. Can you please tell me how to remove the gamepadtokey.js module.
Luke 42239 Posted February 29, 2024 Posted February 29, 2024 11 hours ago, Modex said: I am also having this problem with Thrustmaster pedals. Can you please tell me how to remove the gamepadtokey.js module. HI, we are looking into it. Thanks.
Modex 0 Posted March 1, 2024 Posted March 1, 2024 Luke, can you tell me how to remove the gamepadtokey.js module please, as the_bakken did.
Luke 42239 Posted March 6, 2024 Posted March 6, 2024 On 2/29/2024 at 7:36 PM, Modex said: Luke, can you tell me how to remove the gamepadtokey.js module please, as the_bakken did. Hi, we don't have any official documented way of doing that, but we are working on improving this. Thanks.
learnbyflying 4 Posted March 11, 2024 Posted March 11, 2024 @LukeJust found this thread and can confirm. Thought I was going crazy for a second. I have CH Controls Rudder Pedals plugged in 24/7 which is triggering this. What is the gamepadtokey.js used for and can this safely be renamed to gamepadtokey.js.dis to disable?
Modex 0 Posted March 11, 2024 Posted March 11, 2024 The dev won't tell us. Renaming and restarting the server didn't work for me.
Modex 0 Posted March 13, 2024 Posted March 13, 2024 On 12/03/2024 at 06:23, Luke said: Hi, we are working on improving this. Thanks. Luke, to be fair, you have been saying this for at least 3 years.
