Hi!
My friend is having problems connecting to my emby server using emby for kodi add-on on his Sony Tv... he can reach my server but when he enters the user and password he gets a wrong password or username error message. Only lower case letters are used in the user/pw...  he can connect through a web browser with no problem but can't on kodi for emby... any idea?
Thanks for the help!
quickmic
I need a kodi.log for review after the issue was raised.
Are you absolutely sure the password was correct? How about adding a new user on Emby server, with an even more simple password to rule things out?
I have change the user and pw for a single letter and a single number... let's wait for him to try... i'll update here once I know :)
quickmic
Ok, btw. which login method is he using? Manual server address or Emby connect?
