chevyfan2017 5 Posted January 15, 2023 Posted January 15, 2023 I currently have the "Movie Theme Videos" and "TV Theme Videos" plugins installed, and when I access Emby from my desktop computer and go to a movie, I can see the video background playing in the movie info section, but when I use Emby with my Nvidia Shield and the Emby app (With my videos streamed from my desktop PC) I am unable to see the background video themes for my videos, is there something I am doing wrong? what can I do to make it so that I can see the video backgrounds on my Shield? Thanks!
GrimReaper 4898 Posted January 16, 2023 Posted January 16, 2023 (edited) Andriod TV app does not support theme videos. You can sideload standard Android app which does. https://emby.media/emby-for-android.html Edited January 16, 2023 by GrimReaper Typo
chevyfan2017 5 Posted January 16, 2023 Author Posted January 16, 2023 if I sideload the app, won't it display funny on my TV?
chevyfan2017 5 Posted January 16, 2023 Author Posted January 16, 2023 I sideloaded Emby onto the shield, but it still won't play video backgrounds for any of the movies or TV shows, is there something I need to do?
Solution GrimReaper 4898 Posted January 16, 2023 Solution Posted January 16, 2023 App Settings>Display, make sure "Enable theme videos" option is enabled.
chevyfan2017 5 Posted January 16, 2023 Author Posted January 16, 2023 you are the best!, thanks man!, I got it working I appreciate your help! 1
chevyfan2017 5 Posted January 16, 2023 Author Posted January 16, 2023 One other question...do you know how to put movies into collections? I use to be able to do that where all the Jurassic Park movies showed one cover that said Jurassic Park, and then when I clicked on it, it would take me to all of my jurassic park movies.
GrimReaper 4898 Posted January 16, 2023 Posted January 16, 2023 Three-dot menu (row of icons near the top, next to Filter), enable "Group items into collections" option. 1
chevyfan2017 5 Posted January 18, 2023 Author Posted January 18, 2023 yeah but after doing that, there's no icon on the home page that says "Collections" there use to be an icon that said "Collections" after enabling the Group items into collections option.
Luke 42245 Posted January 19, 2023 Posted January 19, 2023 23 hours ago, chevyfan2017 said: yeah but after doing that, there's no icon on the home page that says "Collections" there use to be an icon that said "Collections" after enabling the Group items into collections option. Check your emby user home screen options. You may have hidden it. The visibility (or lack thereof) is not tied to the group items into collections display option.
