baileyby 2 Posted January 15, 2023 Posted January 15, 2023 Hello, I am having trouble getting emby guide data working after buying a new server. I'm attaching the logs -- it doesn't seem to be able to match the guide data with my stations, as I see repeatedly: EPG channel not found for tuner channel My old server worked fine using (what I think is) the same configuration -- zip code, winttv card, premiere id, etc. Any ideas? Thanks! embyserver.txt
baileyby 2 Posted January 17, 2023 Author Posted January 17, 2023 (edited) Emby guide data, local broadcast. Zip code 72712 Edited January 17, 2023 by baileyby
Solution Luke 42237 Posted January 17, 2023 Solution Posted January 17, 2023 @baileyby Have you checked the channel management screen to see how the tuner channels are mapped to epg channels?
baileyby 2 Posted January 27, 2023 Author Posted January 27, 2023 Hadn't realized I needed to do that or come across it while trying stuff. Thanks!
EmbyOak 23 Posted January 29, 2023 Posted January 29, 2023 I can confirm that the Emby Guide Data is not up to date for all sources. I use Gosfield's channel listing for some channels and it is missing quite a few channels (such as ABC and CBS Buffalo). @cayars
Carlo 4561 Posted January 30, 2023 Posted January 30, 2023 @EmbyOak Can you PM me specifics (postal code, provider) and what you've found? I can provide that information to our provider to get the issue resolved.
