Adam Pessach 2 Posted January 11, 2023 Posted January 11, 2023 on the left side of the home screen in horizontal mode there is a large window displaying the backdrop image of tv shows, movies etc. in previous versions of the emby app in lg, if you were standing on that window the backdrop would appear in the background as well on low opacity. that is not happening in the new update and it is quite annoying as if you are standing on other window panels such as continue watching and latest media the backdrop do appear in the background. I hope you'll be able to fix that problem, although small, in the future.
Luke 42237 Posted January 11, 2023 Posted January 11, 2023 Hi, did you enable backdrops in the app display settings?
Adam Pessach 2 Posted January 11, 2023 Author Posted January 11, 2023 Yes I did, as I explained only while standing on the large window in horizontal mode backdrops don't appear in the background. When I stand on the next episode tile (continue watching) or the latest tv shows it appears.
Happy2Play 9811 Posted January 12, 2023 Posted January 12, 2023 (edited) Do they work at all in TV Mode? Only tested in web client and they don't work at all in TV mode (vertical or horizontal). Edited January 12, 2023 by Happy2Play
Luke 42237 Posted January 12, 2023 Posted January 12, 2023 49 minutes ago, Happy2Play said: Do they work at all in TV Mode? Only tested in web client and they don't work at all in TV mode (vertical or horizontal). Works for me although he's right, just not with the big spotlight item.
