skidmarks 199 Posted January 11, 2023 Posted January 11, 2023 Wasn't sure if i was the beta that i run 99.9% of the time so i decided to check the official release as well. I have added a extras folder to a lot of my TV series folders over the years. Then added a -trailer file here so i could see a series promo (aka trailer) within the series. Right or wrong way to do it i dont know... the last time i looked the wiki doesn't address adding a trailer / promo to TV series. But this method had worked and does work to display trailers with the other methods i have available to me (unless these are not from my local files). I know this did work in roku, but doesnt seem to work any longer. Last night i attempted to just add the -trailer file in the series main folder and that does not seem to work either. Only thing i havent tried was to add a season 0 folder and try it in there. Is there a right way? For TV Series? I have just been mimicking the same setup as movies for this. Thanks....
ebr 16332 Posted January 11, 2023 Posted January 11, 2023 Exactly what are you trying to do? Get a trailer to show up on the detail screen or cinema intros or what?
Solution GrimReaper 4895 Posted January 11, 2023 Solution Posted January 11, 2023 40 minutes ago, skidmarks said: Then added a -trailer file here so i could see a series promo (aka trailer) within the series. Right or wrong way to do it i dont know... 44 minutes ago, skidmarks said: Last night i attempted to just add the -trailer file in the series main folder and that does not seem to work either. 44 minutes ago, skidmarks said: Is there a right way? For TV Series? I have just been mimicking the same setup as movies for this. For TV shows, trailer must be located in \trailers subfolder, <tvshowname>-trailer.ext in main series folder (like for movies) won't do. 1 1
skidmarks 199 Posted January 11, 2023 Author Posted January 11, 2023 (edited) 1 hour ago, ebr said: Exactly what are you trying to do? Get a trailer to show up on the detail screen or cinema intros or what? trying to get the trailer (in this case tv series promo) to play in the detail screen specific to that TV show. Not a random, so people can see what the show is and what its about. worked in roku at one point (i am pretty confident). then the way i was doing it with the extras folder it was working and then not too long ago using this same method a season 0 was being created automatically but at the same time the trailer was available at the same place that the movie trailer would show up in the description screen. Now i dont get anything in roku that will display the trailer / promo file that is marked with the -trailer. It appears according to @GrimReaper post right above that over the years i might have been using another one of my now famous work arounds and what i have been doing should have never worked! Strange i do have all these "trailers" available to me on the server side in TV Series. Which make me now wonder if that is even using my local TV Series "trailer" files? I have never used a trailer folder ever. not during MB or any time till today. But i will make trailer folders for TV Series and report back. I am positive @GrimReaper solution, and sharing his knowledge, with ultimately resolve my issue. Never realized a trailer folder was the key here! Edited January 11, 2023 by skidmarks
Luke 42239 Posted January 11, 2023 Posted January 11, 2023 You can already do this based on what @GrimReaper outlined above.
skidmarks 199 Posted January 11, 2023 Author Posted January 11, 2023 So i have to ask.... if i look at TV series on the server home screen i do get promo / trailers for TV Series. Seems to be only for shows that i added, in my now to find out wrong way, extras->filename-trailer for. So these trailers i see on the server are not coming from my local files? Isn't that a crazy thing... Well thanks everyone, i will make the necessary corrections in my file structure!
Southernskmo 0 Posted February 18, 2025 Posted February 18, 2025 When I tried this on my Syn Nas with the latest Emby, it did not work. The trailers or trailer folder did not even load an nfo or thumb for the video and was not visible on TV. When I used an extras folder, emby loaded it as a special no matter what name I gave it. (all with -trailer). However, when I placed it at the top of the line for season 1 (showname S0-trailer), it called it a -trailer and showed up on my Lgtv Emby and Roku Emby at the top of the season and at the beginning of the list of seasons, instead of as a special. (would like to keep specials separate)
Luke 42239 Posted February 20, 2025 Posted February 20, 2025 @Happy2Playa trailers folder works just fine for you, no?
Happy2Play 9811 Posted February 21, 2025 Posted February 21, 2025 5 hours ago, Luke said: @Happy2Playa trailers folder works just fine for you, no? Correct, I have not issues adding trailers folder for TV.
