Stellarat 12 Posted January 10, 2023 Posted January 10, 2023 (edited) Hi, I'm trying out Premiere and kicking the tyres on its features. I have installed Trailers and Cinema Intros plugins but when I wen to configure Cinema Intros I noticed it was missing the option for upcoming Blu-Ray trailers. I see whereas the doc at https://support.emby.media/support/solutions/articles/44001848833-cinema-intros shows Has this been changed? Am I missing something? Thanks Edited January 10, 2023 by Stellarat
Cheesegeezer 3106 Posted January 10, 2023 Posted January 10, 2023 41 minutes ago, Stellarat said: Hi, I'm trying out Premiere and kicking the tyres on its features. I have installed Trailers and Cinema Intros plugins but when I wen to configure Cinema Intros I noticed it was missing the option for upcoming Blu-Ray trailers. I see whereas the doc at https://support.emby.media/support/solutions/articles/44001848833-cinema-intros shows Has this been changed? Am I missing something? Thanks I have the same also, so i guess the DVD & BD have been removed from the trailer plugin And if you go into the Trailers channel you will only see these 2 Resources
Stellarat 12 Posted January 10, 2023 Author Posted January 10, 2023 1 hour ago, Cheesegeezer said: I have the same also, so i guess the DVD & BD have been removed from the trailer plugin And if you go into the Trailers channel you will only see these 2 Resources That's a shame as this is the only one I want ticked! Can anyone tell us if this was intentional and if so, why?
Solution Luke 42255 Posted January 10, 2023 Solution Posted January 10, 2023 The reason is due to not having a reliable source for those trailers.
Stellarat 12 Posted January 11, 2023 Author Posted January 11, 2023 (edited) 14 hours ago, Luke said: The reason is due to not having a reliable source for those trailers. Ah that's a shame. I have used Amazon in the past to see what what Discs are coming up. Perhaps there's a potential to scrape Amazon to get the titles and then use the usual sources for the trailers (which should already be available)? I'll have a poke around and a think about it... thanks Edited January 11, 2023 by Stellarat
Cheesegeezer 3106 Posted January 11, 2023 Posted January 11, 2023 2 hours ago, Stellarat said: Ah that's a shame. I have used Amazon in the past to see what what Discs are coming up. Perhaps there's a potential to scrape Amazon to get the titles and then use the usual sources for the trailers (which should already be available)? I'll have a poke around and a think about it... thanks If they have an accessible api or resource that is open to the public, then it’s doable, but emby doesn’t scrape or acquire content if it violates any terms of use/service from any providers. 1
