Vkoert 2 Posted January 10, 2023 Posted January 10, 2023 Good day, Hope someone can help me with the following. I installed Emby server on my NAS and made a library from my movies folder on this same NAS. My series are on another NAS, how can i add them to a new library, it keeps failing? Is it a problem that the volume is on another NAS or am I doing something wrong? Thanks in advance, Vincent
Eigeplackter 92 Posted January 10, 2023 Posted January 10, 2023 Can you show us your settings for the tvshows library ? Path I mean. generally that shouldn‘t be a problem, to adress: \\<IPsecondNas>\<sharedfolder> as long as there are matching permissions.
Vkoert 2 Posted January 10, 2023 Author Posted January 10, 2023 Hi, The path to my movies (that is working) is /volume1/Media/Films The path that I tried to make to my other NAS is (folder) \\192.168.178.10\ (Shared network folder) Media\Series Hope this is enough information
Eigeplackter 92 Posted January 10, 2023 Posted January 10, 2023 Check out „Remote Folders“: https://kb.synology.com/en-ph/DSM/help/FileStation/mountremotevolume?version=7 1
Vkoert 2 Posted January 10, 2023 Author Posted January 10, 2023 (edited) Hi Eigeplackter, I tried and it's working. Thanks very much! regards, Vincent Edited January 10, 2023 by Vkoert 1 1
