bigverm23 2 Posted January 9, 2023 Posted January 9, 2023 OS: ubuntu 22.10 Emby Version: docker 4.7.11.0 Platform/player: Chrome Browser the TV Guide is blank, shows no information at all. The Channels, Tags, and Programs tabs all show information as expected.
Luke 42245 Posted January 9, 2023 Posted January 9, 2023 Hi, did you check the sort menu to see if you have a filter applied? What do you see in the programs tab? 1
EODCrafter 181 Posted January 9, 2023 Posted January 9, 2023 Did you install a Guide and Map it to channels?
bigverm23 2 Posted January 9, 2023 Author Posted January 9, 2023 looks like Channel Tags was blank...setting it to ANY works. I wasnt aware I unchecked it but maybe I did at some point.
Luke 42245 Posted January 9, 2023 Posted January 9, 2023 2 minutes ago, bigverm23 said: looks like Channel Tags was blank...setting it to ANY works. I wasnt aware I unchecked it but maybe I did at some point. What happened was you had a filter selected to a tag, and that tag no longer exists. It's something need to look at improving our handling of. 1
