Rumbaar 13 Posted January 8, 2023 Posted January 8, 2023 I've added a number of TV series over the last weeks in bulk, I have RTM on for my TV folder and it appears to be scanning now for hours (8+) after the last import. I can see the percentage indicator constantly going up to '100%' and then resets. How can I see what/monitor what is happening, as it appears to be delaying other manual metadata individual refresh/image updates. In the server settings for running tasks there are none running. Can I stop this without a server shutdown/restart? What is the impact?
Solution Happy2Play 9800 Posted January 8, 2023 Solution Posted January 8, 2023 Restart the server and run full library scan. Happens when many items change so the 60 second trigger happens multiple times. So if editing happens outside Emby you should shut Emby down before hand to stop this item update loop or just allow it to run. 1
Rumbaar 13 Posted January 8, 2023 Author Posted January 8, 2023 8 minutes ago, Happy2Play said: Restart the server and run full library scan. Happens when many items change so the 60 second trigger happens multiple times. So if editing happens outside Emby you should shut Emby down before hand to stop this item update loop or just allow it to run. Ah, I see. Turn off RTM will be the best option. Thanks. 1
