constrict 9 Posted January 7, 2023 Posted January 7, 2023 Is it possible to add an entry to the intro detection to skip certain files or at least to add to the database that if a file is scanned and doesn't have an audio stream it should be skipped in subsequent intro detection scans. Every time I run the intro detection task; I get the following error on any file that doesn't have an audio stream. 2023-01-07 13:28:17.616 Info App: Detecting markers for /mnt/tank2/media/TV Shows/Disney Animated Shorts/Season 1943 - episode /mnt/tank2/media/TV Shows/Disney Animated Shorts/Season 1943/Disney Animated Shorts - s1943e02 - [SDTV] - Education for Death.avi 2023-01-07 13:28:17.617 Info App: /mnt/tank2/media/TV Shows/Disney Animated Shorts/Season 1943 has 1 episodes with audio fingerprints available 2023-01-07 13:28:17.618 Info FfmpegManager: ProcessRun 'CreateTitleFingerprint' Execute: /usr/local/lib/emby-server/bin/ffmpeg -i file:"/mnt/tank2/media/TV Shows/Disney Animated Shorts/Season 1924/Disney Animated Shorts - s1924e04 - [SDTV] - Alice's Fishy Story.mpg" -t 00:10:00.000 -ac 1 -acodec pcm_s16le -ar 16000 -vn -sn -f chromaprint -fp_format raw "/config/cache/temp/ac6ac171673e4bd1af8b9789c4878f62" 2023-01-07 13:28:17.642 Info FfmpegManager: ProcessRun 'CreateTitleFingerprint' Process exited with code 1 - Failed 2023-01-07 13:28:17.642 Error App: CreateTitleFingerprint failed for /mnt/tank2/media/TV Shows/Disney Animated Shorts/Season 1924/Disney Animated Shorts - s1924e04 - [SDTV] - Alice's Fishy Story.mpg to /config/cache/temp/ac6ac171673e4bd1af8b9789c4878f62 2023-01-07 13:28:17.642 Error FfmpegManager: ProcessRun 'CreateTitleFingerprint' Output: 2023-01-07 13:28:17.642 Error FfmpegManager: ProcessRun 'CreateTitleFingerprint' Error Output: ffmpeg version 5.0.0-emby_2022_05_07-spc Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC built with FreeBSD clang version 13.0.0 (git@github.com:llvm/llvm-project.git llvmorg-13.0.0-0-gd7b669b3a303) Execution Date: 2023-01-07 13:28:17 [mpegvideo @ 0x808290000] Estimating duration from bitrate, this may be inaccurate Input #0, mpegvideo, from 'file:/mnt/tank2/media/TV Shows/Disney Animated Shorts/Season 1924/Disney Animated Shorts - s1924e04 - [SDTV] - Alice's Fishy Story.mpg': Duration: 00:11:14.87, bitrate: 1152 kb/s Stream #0:0: Video: mpeg1video, yuv420p(tv), 352x240 [SAR 200:219 DAR 880:657], 1152 kb/s, 29.97 fps, 29.97 tbr, 1200k tbn Output #0, chromaprint, to '/config/cache/temp/ac6ac171673e4bd1af8b9789c4878f62': Output file #0 does not contain any stream
Luke 42290 Posted January 20, 2023 Posted January 20, 2023 hi @constrict yes, we'll take a look at this. Thanks for reporting.
