Mentalblaze 9 Posted January 6, 2023 Posted January 6, 2023 (edited) My son have problems when he use Emby on his mobile phone and cast to Chromecast. (Mobile Galaxy S22 ultra Android 13 and Emby app v. 3.2.90) It works fine until he pasues and then tries to resume. This time the Chromecast disconected by itself and it was not possible to resume or to use fastForward to resume from the correct position. Is there some issue around this or a setting I need to tweak for his user or all users? I have not seen these issues myself, so I can't really test things here. I'll attach the last log file where the issue happened somewhere around 11:30 - 11:50 something. But I attach the whole day, if there is useful info earlier (even if I doubt that). EmbyLogs.txt Edited January 6, 2023 by Mentalblaze
nospotify 187 Posted January 6, 2023 Posted January 6, 2023 @Mentalblaze This seems same/related to problem reported by multiple users here: and here 1
Mentalblaze 9 Posted January 7, 2023 Author Posted January 7, 2023 Thanks. He uses an older Chromecast and not the newer one with GoogleTV, but the symptoms are the same. And as I mostly use x265 now, it is probably .mkv that he has tried.
Carlo 4561 Posted June 29, 2023 Posted June 29, 2023 On 1/7/2023 at 3:46 AM, Mentalblaze said: Thanks. He uses an older Chromecast and not the newer one with GoogleTV, but the symptoms are the same. And as I mostly use x265 now, it is probably .mkv that he has tried. I think more and more people are starting to have problems with these older devices simply because we're moving past their time. Gen 1 & 2 CCs only supported VP8 and H.264 to a resolution of 1080p/30fps. 3rd gen raised H.264 from level 4.1 to 4.2 with 1080p.60fps. The CC Ultra was the first CC to support HEVC for example. https://developers.google.com/cast/docs/media#chromecast_1st_and_2nd_gen Chromecast 1st and 2nd Gen. H.264 High Profile up to level 4.1 (720p/60fps or 1080p/30fps) VP8 (720p/60fps or 1080p/30fps) Chromecast 3rd Gen H.264 High Profile up to level 4.2 (1080p/60fps) VP8 (720p/60fps or 1080p/30fps) Chromecast Ultra H.264 High Profile up to level 4.2 (1080p/60fps) VP8 (4K/30fps) HEVC / H.265 Main and Main10 Profiles up to level 5.1 (4K/60fps) VP9 Profile 0 and Profile 2 up to level 5.1 (4K/60fps) High Dynamic Range (HDR) Dolby® Vision™ HDR10 Chromecast with Google TV H.264 High Profile up to level 5.1 (4Kx2K/30fps) HEVC / H.265 Main and Main10 Profiles up to level 5.1 (4Kx2K@60fps) VP9 Profile-2 up to 4Kx2K@60fps Google Nest Hub H.264 High Profile up to level 4.1 (720p/60fps) VP9 up to level 4.0 (720p/60fps) Nest Hub Max H.264 High Profile up to level 4.1 (720p/30fps) VP9 up to level 4.0 (720p/30fps) Audio codecs Chromecast Audio, Google Home, and Google Home Mini support the following list of codecs: FLAC (up to 96kHz/24-bit) HE-AAC LC-AAC MP3 Opus Vorbis WAV (LPCM) WebM
