pwhodges 2033 Posted January 28, 2025 Posted January 28, 2025 On the main Emby download page select your platform and one of the options will be to download the beta; download, install and run. Note that once you change an installation to the beta, changing it back will break it. That said, many people find it reliable enough to run routinely - it's your choice depending on the reliability level you require. Paul
gillmacca01 220 Posted January 28, 2025 Posted January 28, 2025 32 minutes ago, pwhodges said: On the main Emby download page select your platform and one of the options will be to download the beta; download, install and run. Note that once you change an installation to the beta, changing it back will break it. That said, many people find it reliable enough to run routinely - it's your choice depending on the reliability level you require. Paul Bear in mind, there is no beta currently for live tv, if that's what you are after
markyp 38 Posted January 28, 2025 Posted January 28, 2025 (edited) it was... hence the wink! I'm already on the beta channel for the server, and I'm assuming there'll be some kind of closed-group testing of tv-next before it hits the normal beta channel? As a very frequent user of Live TV I'm keen to test the new functionality when its appropriate. Edited January 28, 2025 by markyp 1
softworkz 5133 Posted January 28, 2025 Posted January 28, 2025 9 hours ago, markyp said: I'm assuming there'll be some kind of closed-group testing of tv-next before it hits the normal beta channel? Yup 2
arrbee99 1836 Posted January 29, 2025 Posted January 29, 2025 The cynic in me says Donald Trump will become a caring, sharing tree-huger before we see TVnext. 7
Carlo 4561 Posted January 29, 2025 Posted January 29, 2025 20 hours ago, arrbee99 said: The cynic in me says Donald Trump will become a caring, sharing tree-huger before we see TVnext. TVnext will surely be here first, otherwise, I guess we'll have the biggest, best and most beautiful trees ever seen. Tremendous forests, folks! Carlo PS While I'd hope the above comes across funny, and didn't cross the line for anyone, we should try and avoid bringing politics into the forum, as there is always the possibility it offends someone.   1
arrbee99 1836 Posted January 29, 2025 Posted January 29, 2025 I know. Sorry. I''ll try to be better. 2
ebr 16334 Posted January 30, 2025 Posted January 30, 2025 12 hours ago, denz said: Are we getting closer to testing ? There is really no need to ask this question until after 4.9 is released and a new beta cycle is started. Thanks. 1
Dibbes 515 Posted January 30, 2025 Posted January 30, 2025 33 minutes ago, ebr said: There is really no need to ask this question until after 4.9 is released and a new beta cycle is started. Thanks. We're not really asking, just expressing impatience and frustration 1
Dibbes 515 Posted January 30, 2025 Posted January 30, 2025 2 hours ago, gillmacca01 said: Good things come to those that wait So does old age 3
neik 874 Posted January 30, 2025 Posted January 30, 2025 5 hours ago, ebr said: There is really no need to ask this question until after 4.9 is released and a new beta cycle is started. Thanks. If so many people are asking then maybe priorities need to be shifted, no? Just asking... 3
denz 501 Posted January 31, 2025 Posted January 31, 2025 4.9 was supposed to be a shorter beta but it has been a year now. To me that is a very long beta cycle. With TVnext there will be much more users participating in the beta cycle. Â
pwhodges 2033 Posted January 31, 2025 Posted January 31, 2025 13 hours ago, neik said: If so many people are asking then maybe priorities need to be shifted, no? That is how the status changed from being unsure whether they wanted to implement it at all to committing to which beta cycle it would come in. Paul 1
Ugnaughts 53 Posted January 31, 2025 Posted January 31, 2025 after reading over most this thread. im still a little unsure what tvnext is? sounds like a proxy like xteve that creates more of a buffer on streams and maybe a way to manage streams that are open but should be closed. which keeps from going over stream limit from provider. am i correct? i use latest beta, has it been implemented yet? i found that there is an issue that started somewhere in the beta versions for playing 265 streams. i tested the portable version 4.8.10.0 and beta 4.9.0.37. the old version plays hvec stream ok. new beta wont. did fresh install new library on both. both use same plugins. so something changed that allows hvec/265 streams to play. i would switch back to the older version. although it causes issues with db. most likely db changes as they went. thats another reason i created my app that resolves some on going issues ive had. it exports favs and played status to csv file the imports( doesn't use emby api but sql cmds. ) so as long as emby doesn't change the structure/location of data in db then it should work on other versions of emby. problem is if i have to rescan all the strm files from iptv provider takes 3 days around the clock the first time and makes emby unusable during that time.Â
bungee91 133 Posted January 31, 2025 Author Posted January 31, 2025  9 minutes ago, joekingcool said: after reading over most this thread. im still a little unsure what tvnext is? sounds like a proxy like xteve that creates more of a buffer on streams and maybe a way to manage streams that are open but should be closed. which keeps from going over stream limit from provider. am i correct?  On 3/8/2024 at 4:59 PM, TMCsw said: Have you looked at this?: https://docs.google.com/spreadsheets/u/0/d/e/2PACX-1vTtWQwRLBTPp5TNh8KmtSH3Rvz9Zm6ovUL__YL9Ax1ikzGLCzdfhryjMJ6-g5N1rJIf5LrDGjE5jqds/pubhtml?gid=1930489182&single=true&pli=1 TVnext Is a lot more than just tuners... ...and besides that it's mostly done. But i suppose your happy using a Vic 20 and driving a model T Â
Ugnaughts 53 Posted January 31, 2025 Posted January 31, 2025 6 minutes ago, bungee91 said: Â Â ok just looked over that comparison. but sounds like its a media center software like emby but much more features? i cant find any info on it threw google search? some site in Korean. sorry but you added more confusionÂ
softworkz 5133 Posted January 31, 2025 Posted January 31, 2025 This is an upcoming update to Emby, not something separate. I has only be developed in parallel due to its complexity. 1
Sammy 791 Posted January 31, 2025 Posted January 31, 2025 21 hours ago, neik said: If so many people are asking then maybe priorities need to be shifted, no? Just asking... .. for a friend? Â 2
softworkz 5133 Posted January 31, 2025 Posted January 31, 2025 On 1/29/2025 at 10:06 PM, Carlo said: On 1/29/2025 at 1:13 AM, arrbee99 said: The cynic in me says Donald Trump will become a caring, sharing tree-huger before we see TVnext. TVnext will surely be here first, otherwise, I guess we'll have the biggest, best and most beautiful trees ever seen. Tremendous forests, folks! This is the MEGA project! Make Emby Greater Again  2 4
arrbee99 1836 Posted January 31, 2025 Posted January 31, 2025 not withstanding your outstanding work, at the moment I'd go for MEAGER - Make Emby App Great Eventually Right ? 2
justinrh 267 Posted January 31, 2025 Posted January 31, 2025 21 hours ago, denz said: 4.9 was supposed to be a shorter beta but it has been a year now. To me that is a very long beta cycle. With TVnext there will be much more users participating in the beta cycle. The development cycle is sooo long and unpredictable. The product I work on for my employer has millions of LoC and we push out updates once a month and new versions once a year. Emby's lack of updates bewilders me. 1
