PeteGul 41 Posted January 5, 2023 Posted January 5, 2023 Hi 1:Is there an way to let the screensaver kick in? I use this app in ATV because this app is generally better than the one for ATV. 2:And is there an way to force emby to choose 5.1 instead of stereo, even if the stereo is marked as default in the media file? This question will be the same for the ATV version, in my mind the ATV version did this, but it didn't .. Thanks in advance
Luke 42243 Posted January 10, 2023 Posted January 10, 2023 Hi, there is currently no way to do this, although this topic has come up before and having some way to address this is likely for future updates. Thanks. 1
PeteGul 41 Posted January 10, 2023 Author Posted January 10, 2023 Hope there wil.. for both the questions. But, maybe the Android app it self could be used as Android TV app also. So you just need to "take care" of one app instead?
Solution GrimReaper 4897 Posted January 10, 2023 Solution Posted January 10, 2023 (edited) 4 minutes ago, pettergulbra said: maybe the Android app it self could be used as Android TV app also. So you just need to "take care" of one app instead? Unfortunately, that has been long-time incoming and standard Android app will supersede AndroidTV app in not-too-distant future, as it seems currently. Edited January 10, 2023 by GrimReaper Link 1
PeteGul 41 Posted January 11, 2023 Author Posted January 11, 2023 That will be a good thing I think. Thanks
