As777 27 Posted January 3, 2023 Posted January 3, 2023 (edited) Is there anyway to make Emby mobile transcode lossless to lossy (flac to mp3 or vorbis, in my case)? I would like to use less mobile data when streaming from my flac collection. Vorbis would be idea. Ideally, in the same way you can make video transcode, Edited January 3, 2023 by askog666
Solution pwhodges 2033 Posted January 3, 2023 Solution Posted January 3, 2023 In the playback settings for the app, in the audio section you can set the bit rate (under "Internet quality") to something appropriate. You can't specify the encoding used - I'd assume it's MP3 for total compatibility, so 192bps would be a sensible value. Paul
