copyfile 0 Posted December 30, 2022 Posted December 30, 2022 I installed the Emby server on my synology NAS and configured everything and added my tv shows to the library. These all show up on the server. I also installed the Kodi package on my Nvidia Shield (Emby-Next-Gen) where it works perfectly. I see all the shows, can play then, the current position is shown on the Emby server etc. When I do the same on my Kodi Fire TV 4K it also shows all my tv shows, and when I try to resume one it also shows the current position. But the problem is when trying to play something, whatever file/tv show I try they all give the same error message 'One or more items failed to play. Check the log for more information about this message'. Below is the part of the log that I can see on the Emby server at the time I tried to play the video. Any idea what I can/need to do to get this fixed? 2022-12-30 15:34:16.114 Info HttpServer: WS http://diskstation:8096/embywebsocket?api_key=e0e08afdd5074a7c8889aef71e011865&deviceId=65a4f9d4-6f2d-4b3e-bdc8-da260cf42fb1. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:108.0) Gecko/20100101 Firefox/108.0 2022-12-30 15:34:29.070 Info Server: SocketException: http://diskstation:8096/favicon.ico 2022-12-30 15:34:39.513 Info HttpServer: WS http://diskstation:8096/embywebsocket?api_key=e0e08afdd5074a7c8889aef71e011865&deviceId=65a4f9d4-6f2d-4b3e-bdc8-da260cf42fb1. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:108.0) Gecko/20100101 Firefox/108.0
Eigeplackter 92 Posted December 30, 2022 Posted December 30, 2022 Ummm if we are talking about a FireTV Stick, why does it say: Quote UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15 Seems like wrong part of the log.
copyfile 0 Posted December 30, 2022 Author Posted December 30, 2022 That is strange indeed. Not sure if the FireTV app is writing the log to the server then? Attached is the complete Embyserver log file hopefully this helps. embyserver.txt
Eigeplackter 92 Posted December 30, 2022 Posted December 30, 2022 Maybe rotate log file on server, and just start 1 movie on fireTV and repost new log. But why are you using KODI on FireTV, why not the native Emby app ?
copyfile 0 Posted December 30, 2022 Author Posted December 30, 2022 I did rotate the log files and then tried to play 3 episodes with all the same issue. Attached the log file but it looks like it not adding anything to the log file. Anything I can do to fix that as well? I will also try the native Emby app, didn't know that that one existed. But still would like to try and get Kodi working as well if possible embyserver.txt
Eigeplackter 92 Posted December 30, 2022 Posted December 30, 2022 As I‘m not using KODI on Fire, I can‘t help you there. Just to be sure: FireTV -> Kodi -> emby-next-gen (Addon Mode ?) -> Emby Server on Synology (nativ or docker ?)
copyfile 0 Posted December 30, 2022 Author Posted December 30, 2022 The emby next gen module in Native mode (can try the other mode if that can help?) And on Synology the server runs native as my nas doesn't support docker (older nas). Thanks for the help!
quickmic 1709 Posted December 30, 2022 Posted December 30, 2022 (edited) 4 minutes ago, copyfile said: The emby next gen module in Native mode (can try the other mode if that can help?) And on Synology the server runs native as my nas doesn't support docker (older nas). Thanks for the help! Don't use native mode. This is for edge cases and just causes troubles if you are not an expert in Lan/Network infrastructure. Edited December 30, 2022 by quickmic 1
quickmic 1709 Posted December 30, 2022 Posted December 30, 2022 (edited) btw, native/addon mode for next-gen plugin has nothing to do with Emby server. It defines how to access the content. Edited December 30, 2022 by quickmic
copyfile 0 Posted December 30, 2022 Author Posted December 30, 2022 Just did a fresh re-install and choose the addon mode but still the same issue. I see all my files/episodes but when I try to play them it says that the file is not available
Eigeplackter 92 Posted December 30, 2022 Posted December 30, 2022 I saw in your logfiles, that you used the DNS-Name, was that auto-discovered ? Might be worth a try using the IP instead.
copyfile 0 Posted December 30, 2022 Author Posted December 30, 2022 It is indeed auto generated the dns name. I just tried with the Ip instead but same issue unfortunately. 1
Eigeplackter 92 Posted December 31, 2022 Posted December 31, 2022 Hmmm I'm at wits end, I'd really try the native emby app and see how that behaves.
copyfile 0 Posted January 1, 2023 Author Posted January 1, 2023 Thanks again for the help, below the link to the kodi log file I just generated. I tried to run a few Wednesday episodes and Welcome to Wexham episode which failed with the same error message regarding the file not existing. https://paste.kodi.tv/qipehekeda
quickmic 1709 Posted January 1, 2023 Posted January 1, 2023 (edited) You are using native mode and you cannot access your network share. Not a plugin issue, as I told you. Native mode only causes troubles. You need to fix network/permission issues or change to addon mode. 2023-01-01 15:23:08.037 T:19587 INFO <general>: INFO: EMBY.hooks.player: [ onPlayBackStarted ] 2023-01-01 15:23:08.071 T:19883 ERROR <general>: SMBDirectory->GetDirectory: Unable to open directory : 'smb://192.168.1.28/Series/Wednesday' unix_err:'1' error : 'Operation not permitted' 2023-01-01 15:23:08.071 T:19883 ERROR <general>: GetDirectory - Error getting smb://DiskStation/Series/Wednesday/ 2023-01-01 15:23:08.167 T:19883 ERROR <general>: SMBDirectory->GetDirectory: Unable to open directory : 'smb://192.168.1.28/Series/Wednesday' unix_err:'1' error : 'Operation not permitted' 2023-01-01 15:23:08.167 T:19883 ERROR <general>: GetDirectory - Error getting smb://DiskStation/Series/Wednesday/ 2023-01-01 15:23:08.251 T:19883 INFO <general>: SMBFile->Open: Unable to open file : 'smb://192.168.1.28/Series/Wednesday/Wednesday%20-%20S01E08.mkv' unix_err:'d' error : 'Permission denied' 2023-01-01 15:23:08.252 T:19883 ERROR <general>: CFileCache::Open - <smb://DiskStation/Series/Wednesday/Wednesday - S01E08.mkv> failed to open Edited January 1, 2023 by quickmic
