justinrh 267 Posted December 30, 2022 Posted December 30, 2022 (edited) Refer to this post for the video in question and media details. Can someone explain what I'm seeing the TV say the audio is? I appears to me the audio is being upgraded. If so, why? Shouldn't Emby and the Shield just passthru to the 'everything' soundbar? "DD+" is an upgrade, right? "Dolby processing" on the Shield is off. The TV system menu stats say: audio in = Dolby Audio audio out = Dolby Atmos - DD+ Edited December 30, 2022 by justinrh
ebr 16337 Posted December 30, 2022 Posted December 30, 2022 Sounds like your TV is converting it. The "audio in" part would be what is being passed by Emby.
justinrh 267 Posted December 30, 2022 Author Posted December 30, 2022 Why isn't Emby passing to the TV the format it is, which is Atmos: Format : E-AC-3 JOC Format/Info : Enhanced AC-3 with Joint Object Coding Commercial name : Dolby Digital Plus with Dolby Atmos Format settings : Dolby Surround EX
ebr 16337 Posted December 31, 2022 Posted December 31, 2022 I'm not really sure what your TV is reporting nor what kind of processing it may be doing but, if you will play that item for a few seconds and then follow the instructions to send a log from the app I can tell you what we are sending out.
justinrh 267 Posted December 31, 2022 Author Posted December 31, 2022 Logs sent at 11:19 am EST, user Home. BTW, the Android app (v3.2.44) croaks on this file.
ebr 16337 Posted January 2, 2023 Posted January 2, 2023 On 12/31/2022 at 11:23 AM, justinrh said: Logs sent at 11:19 am EST, user Home. BTW, the Android app (v3.2.44) croaks on this file. How was the file created?
justinrh 267 Posted January 2, 2023 Author Posted January 2, 2023 You said you could tell what Emby is sending out. What did you find?
ebr 16337 Posted January 3, 2023 Posted January 3, 2023 It is direct playing and sending the raw audio out - which, in this case, was DD+ (EAC3). 1
Solution justinrh 267 Posted January 3, 2023 Author Solution Posted January 3, 2023 Well, since I'm getting out what is going in, then the TV is just not reporting the proper (complete) info for IN like it does OUT.
justinrh 267 Posted January 6, 2023 Author Posted January 6, 2023 Unless someone says my conclusion is bogus, then yes.
