GrimReaper 4896 Posted December 29, 2022 Posted December 29, 2022 (edited) 4.7.11.0 server with VirtualTV 1.1.3 plugin Trying to get rid (and failing) of "Premiere" badge which has been deselected in Guide Show Indicators dialog: While that works for the Guide itself, same selection is not honored throughout the UI and same is getting applied to: 1. Guide item details 2. On Now row, both on Home Screen and Programmes tab: 3. Channel tab Channel images, irrespective of Primary type selection: 4. Channel schedule: Kindly make it so that Indicator (not necessarily restricted to "Premiere" tag) is honored in all other sections following user's selection in the Guide settings (that being the only spot where selection is possible). @pünktchen for reference only. Edited December 29, 2022 by GrimReaper
ebr 16335 Posted December 29, 2022 Posted December 29, 2022 3 minutes ago, GrimReaper said: same selection is not honored throughout the UI It isn't intended to and I don't really think it should as that is a guide-specific settings screen. The only reason that option exists in the guide is so that the guide display doesn't get too cluttered if you don't happen to care about those items. We would have to have some other option to control showing it on the posters but I think it should remain on the detail screen.
GrimReaper 4896 Posted December 29, 2022 Author Posted December 29, 2022 3 minutes ago, ebr said: We would have to have some other option to control showing it on the posters That would work also, as long it is removed. Thanks.
