adminExitium 356 Posted February 1, 2023 Posted February 1, 2023 3 minutes ago, Marc0 said: Complete not clear what "UpdateType" is... Present in the corresponding file in Sonarr: https://github.com/Sonarr/Sonarr/blob/ad42d4a14c814d5911dafb5e78e97ec09b4b13a5/src/NzbDrone.Core/Notifications/MediaBrowser/MediaBrowser.cs i.e. Created, Modified & Deleted. 3 minutes ago, Marc0 said: Doesn't seem the work for me.... I run the latest develop version As Luke pointed out earlier, we need debug logs from your Emby instance when the corresponding Sonarr/Radarr event was received: 1
Luke 42243 Posted February 1, 2023 Posted February 1, 2023 6 hours ago, Marc0 said: Complete not clear what "UpdateType" is... Created/Modified/Deleted But it can also be omitted.
Marc0 29 Posted February 1, 2023 Author Posted February 1, 2023 1 minute ago, Luke said: Created/Modified/Deleted But it can also be omitted. @Luke: thanks got it working now. Question: still have problems with the trigger sonarr/radarr with is build in default. I will report a problem soon. I don't use it anymore because this script runs now. But maybe you can improve Emby when it gets clear why the default trigger from sonarr and radarr aren't working. 1
Marc0 29 Posted February 2, 2023 Author Posted February 2, 2023 On 1/20/2023 at 6:20 PM, Luke said: Don't know. We'd have to look at an example. How to Report a Problem Thanks. Hi Luke, The Sonarr and Radarr triggers are also solved now! Problem (or fact if you want to call it that way), is that the path for (son)(rad)arr content must be the same as for Emby , just the same when you want to use /emby/Library/Media/Updated?api_key So by solving that problem, the native triggers from (son)(rad)arr were solved... too. Since I run all services in containers, I could easily fix this problem with the paths..... 1
plexstreams1 3 Posted October 9, 2023 Posted October 9, 2023 Did you ever resolve this? I am having the same issue. For example, when a file is deleted on a file system and I use the API /emby/Library/Media/Updated To inform Emby of it, the movie/file is still in the library.
Marc0 29 Posted October 10, 2023 Author Posted October 10, 2023 5 hours ago, plexstreams1 said: Did you ever resolve this? I am having the same issue. For example, when a file is deleted on a file system and I use the API /emby/Library/Media/Updated To inform Emby of it, the movie/file is still in the library. Check this. https://mjanssen.nl/2023/02/02/getting-your-emby-library-scanned-for-new-content-in-four-ways/
Marc0 29 Posted October 10, 2023 Author Posted October 10, 2023 On 2/2/2023 at 7:10 PM, Marc0 said: Wrote in all up NEW URL: https://mjanssen.nl/2023/02/02/getting-your-emby-library-scanned-for-new-content-in-four-ways/ 1
Marc0 29 Posted March 8, 2025 Author Posted March 8, 2025 On 10/10/2023 at 7:46 AM, Marc0 said: NEW URL: https://mjanssen.nl/2023/02/02/getting-your-emby-library-scanned-for-new-content-in-four-ways/ https://micro.mjanssen.nl/2024/12/07/getting-your-emby.html 1
Jdbye 4 Posted April 22, 2025 Posted April 22, 2025 On 3/8/2025 at 11:03 AM, Marc0 said: https://micro.mjanssen.nl/2024/12/07/getting-your-emby.html The blog post contains some useful information, but there is a much easier way to handle differing paths that isn't mentioned. The Emby connection in sonarr/radarr has an option to map one path to another, which is visible when you enable advanced settings. This method works perfectly for me. 1
