Luke 42244 Posted November 15, 2023 Posted November 15, 2023 On 11/1/2023 at 10:32 PM, Saitama1979 said: Downloaded from the site. 3.3.41 Can you try sideloading the latest and seeing if it still happens? Thanks.
Saitama1979 0 Posted November 15, 2023 Posted November 15, 2023 11 hours ago, Luke said: Can you try sideloading the latest and seeing if it still happens? Thanks. Done. Seems fine so far. But something I've noticed with the android app on the shield. The images seem to be low res / quality. Almost blurry. Compared to the Android TV app. Even on the Google TV home screen, the continue playing for the android app is very low quality. But it's perfectly fine if using the TV app. Is there a fix for this?
Luke 42244 Posted November 16, 2023 Posted November 16, 2023 12 hours ago, Saitama1979 said: Done. Seems fine so far. But something I've noticed with the android app on the shield. The images seem to be low res / quality. Almost blurry. Compared to the Android TV app. Even on the Google TV home screen, the continue playing for the android app is very low quality. But it's perfectly fine if using the TV app. Is there a fix for this? Hi, please open a new topic and provide an example. Thanks !
