dimitrik 14 Posted December 28, 2022 Posted December 28, 2022 Hi, I've recently started using Emby Theater (the windows .exe version, not the store version) full time in my Windows 10 HTPC. I set ET to autostart with windows and I want to use it with an MCE Remote which always worked well with MediaBrowser / Emby WMC etc. With Emby Theater however, I need to use a mouse or keyboard, to click on ET before the MCE remote will work. I assume this means the app is not in focus, even though it is running full screen. Has anyone come across this and figured out a solution? Also, is there a way to start ET from the remote? Autostart is OK, but this functionality would be useful. Many thanks for any advice!
Luke 42237 Posted January 4, 2023 Posted January 4, 2023 Hi, yes this has been reported once or twice before although it doesn't seem to impact everyone. We'll take a look at it. Thanks.
