papugo1980 4 Posted July 30, 2023 Posted July 30, 2023 7 hours ago, vaise said: Is this directed to emby support? As that is not a solution for media owners with thousands if not tens of thousands of files that play fine with jellyfin. The issue is not the media. yes but at least by doing so I was able to buffer the problem, this job is done when I use chromcast
Luke 42245 Posted August 11, 2023 Posted August 11, 2023 What server version and operating system are you guys on?
papugo1980 4 Posted August 11, 2023 Posted August 11, 2023 (edited) 1 hour ago, Luke said: What server version and operating system are you guys on? 4.7.13.0 synology nas Dsm 7.2 Edited August 11, 2023 by papugo1980
vaise 340 Posted August 11, 2023 Posted August 11, 2023 Beta 39. Can’t go to .40 until the password requirement is removed on lan. unraid docker container.
pwhodges 2033 Posted August 11, 2023 Posted August 11, 2023 18 minutes ago, vaise said: Can’t go to .40 until the password requirement is removed on lan. You do realise, I hope, that it won't be removed. What will happen, as far as I can see, is improved memory for multiple user logins at the clients. Paul
vaise 340 Posted August 11, 2023 Posted August 11, 2023 5 minutes ago, pwhodges said: You do realise, I hope, that it won't be removed. What will happen, as far as I can see, is improved memory for multiple user logins at the clients. Paul As I said in my post on the subjects, we have multiple rooms with shared tv access, so 6 profiles. 2 of those can’t enter a password when they click on. Their face as they are too young. The clicking on another user must be remembered in lan for all. Once during setup is ok but never again. Another is the wife and if they force her to put a password in EVER (except maybe once only) on the lan, that will be unfortunately be the end of emby for us. there are many others in the same boat. And we are just the beta people. Imagine the thousands of others.
pwhodges 2033 Posted August 11, 2023 Posted August 11, 2023 The multiple remembered logins will mean that once each is logged in with password they can be switched to without password (this has already been added to the beta client for Roku, but I haven't tested it yet) - so long as they are not explicitly logged out. Paul
vaise 340 Posted August 11, 2023 Posted August 11, 2023 (edited) 14 minutes ago, pwhodges said: The multiple remembered logins will mean that once each is logged in with password they can be switched to without password (this has already been added to the beta client for Roku, but I haven't tested it yet) - so long as they are not explicitly logged out. Paul explicitly logged out ? thaty is something we often do here. I guess the 'change user' feature does not log out. If that is the solution, then we will have to get in the habit of doing that. I am not going to be popular around here until that is set in stone with everyone. Out emby startup is set to always show the profiles to pick from - it had better be remembering the password then. Edited August 11, 2023 by vaise
robbom 5 Posted August 11, 2023 Posted August 11, 2023 5 hours ago, Luke said: What server version and operating system are you guys on? Windows 10 and I moved to the Beta 4.8.0.40 in trying to trouble shoot the issue
vaise 340 Posted August 20, 2023 Posted August 20, 2023 Beta .42 has not fixed anything on here.......
vaise 340 Posted September 7, 2023 Posted September 7, 2023 All please try the latest Emby for GoogleTV beta app. Its fixed all my issues. 2.0.93 (7 Sep) Tweak Exo settings 1 1 1
robbom 5 Posted September 8, 2023 Posted September 8, 2023 3 hours ago, vaise said: All please try the latest Emby for GoogleTV beta app. Its fixed all my issues. 2.0.93 (7 Sep) Tweak Exo settings Where can I find this beta?
seanbuff 1356 Posted September 8, 2023 Posted September 8, 2023 10 minutes ago, robbom said: Where can I find this beta? You will need to sideload to your device. 1
vaise 340 Posted September 8, 2023 Posted September 8, 2023 If you have not registered for the androidTV beta, then you wiull have to sideload as @seanbuffsays. If you use the emby beta server version, then you should maybe also signup for the android beta, then you can just update the app from the google play store in the normal way, or wait for it to auto update. 1
papugo1980 4 Posted September 8, 2023 Posted September 8, 2023 I also confirm, with this beta the problem has finally been solved
robbom 5 Posted September 8, 2023 Posted September 8, 2023 (edited) 7 hours ago, vaise said: All please try the latest Emby for GoogleTV beta app. Its fixed all my issues. 2.0.93 (7 Sep) Tweak Exo settings THis update has fixed it with out any other settings changes I did the side loading Edited September 8, 2023 by robbom
Trevor68 70 Posted September 8, 2023 Posted September 8, 2023 I'm in the beta channel, but only have 2.0.92 installed? Is there a way to update besides sideloading?
vaise 340 Posted September 8, 2023 Posted September 8, 2023 (edited) 4 minutes ago, Trevor68 said: I'm in the beta channel, but only have 2.0.92 installed? Is there a way to update besides sideloading? I just went to the google play store on the TV, searched for emby, selected it and clicked update Edited September 8, 2023 by vaise
