KodiTV72 3 Posted January 15, 2023 Posted January 15, 2023 On 1/4/2023 at 11:53 PM, DerFox said: I solved this Problem by: Updating to the latest beta server version of Synology (i think 4.0.8.21). Then go to your User Settings (On Android,Web,Windows) Go to your User that you want to play on your LG Tv.聽 Look for the Playback Settings and unmark Video Transcoding. I did a manual update of my Synology to 4.7.11.0 and it fixed the DTS issues. Then I went to the beta version聽4.8.0.21, and disabled video transcoding. Everything is now back to normal and working on the LG app 1.0.37 Thanks for the tips. 聽 It took me ages to find the playback settings. To be clear the playback settings are set on the server. They are not the playback settings in the LG app.
caaptusss 21 Posted January 18, 2023 Posted January 18, 2023 (edited) I hope @Lukewill find a similar solution for the linux emby server soon. All my family has to become injury me Edited January 18, 2023 by caaptusss
Utini 14 Posted January 25, 2023 Posted January 25, 2023 On 1/10/2023 at 7:27 PM, Utini said: Hi there, I just played the file exactly until a freeze happened. Once the freeze was over I stopped and opened the log file. log file + mediainfo of the video file are attached. mediainfo.txt 30.93 kB聽路聽2 downloads embyserver.txt 46.11 kB聽路聽2 downloads @Lukenot sure if I am haunted by the same issue as OP but for me it is impossible to watch 4k HDR content. Constant freezes while playing :S
Luke 42237 Posted January 25, 2023 Posted January 25, 2023 This is resolved for the next update to the Emby LG app. Thanks. 2
caaptusss 21 Posted January 25, 2023 Posted January 25, 2023 1 hour ago, Luke said: This is resolved for the next update to the Emby LG app. Thanks. Have you a date for the next update on the LG store ? Thanks,
Luke 42237 Posted January 25, 2023 Posted January 25, 2023 I don't have an ETA yet, but we are working on it. 1
Utini 14 Posted January 26, 2023 Posted January 26, 2023 21 hours ago, Luke said: This is resolved for the next update to the Emby LG app. Thanks. Awesome, thank you! Great work as always 1
