BorKon 1 Posted December 26, 2022 Posted December 26, 2022 Hi everyone, I'm new to emby. I'm currently using emby server on my old qnap nas, and that part works flawlessly. On my kodi (without emby) I have no issues downloading subtitles, however using emby next gen most tv shows wont download subtitles. I can play subtitles that are already available in videos but whenever I want to download there is a message with rendom letters (quit long). Works fine with most movies so far, but most tv shows don't work. Anyone having same issues?
quickmic 1709 Posted December 26, 2022 Posted December 26, 2022 How do you download subtitles? On Emby server or via Kodi?
BorKon 1 Posted December 26, 2022 Author Posted December 26, 2022 I tried only via kodi, than both. But it works with movies. Also it works if I use embycon or without amby at all
quickmic 1709 Posted December 26, 2022 Posted December 26, 2022 43 minutes ago, BorKon said: I tried only via kodi, than both. But it works with movies. Also it works if I use embycon or without amby at all Well via Emby server it should work, via Kodi probably only if you use native mode.
BorKon 1 Posted December 30, 2022 Author Posted December 30, 2022 But how can it download for movies without issues? It only has issues with Tv shows
quickmic 1709 Posted December 30, 2022 Posted December 30, 2022 I checked and opensubtitles.org is working on Kodi in addon mode. Unless I got DETAILED issue description form you, I cannot review the issue.
BorKon 1 Posted December 30, 2022 Author Posted December 30, 2022 ok here it goes. When i use emby for next gen kodi and want to download subtitles with either opensubtitle.org or opensubtitles.com, I can search and it will list all the available subtitle but when I want to download them it closes the windows and very long message appears at bottom with random letters. the message is very long and it appears only for few seconds so I cant tell you what exactly is written. the issue appears only on tv shows with emby next gen for kodi. movies work fine under the same addon. same steps work fine under embycon addon or without emby addons when I just open a show with kodi and not through addon.
quickmic 1709 Posted December 30, 2022 Posted December 30, 2022 25 minutes ago, BorKon said: ok here it goes. When i use emby for next gen kodi and want to download subtitles with either opensubtitle.org or opensubtitles.com, I can search and it will list all the available subtitle but when I want to download them it closes the windows and very long message appears at bottom with random letters. the message is very long and it appears only for few seconds so I cant tell you what exactly is written. the issue appears only on tv shows with emby next gen for kodi. movies work fine under the same addon. same steps work fine under embycon addon or without emby addons when I just open a show with kodi and not through addon. It's really important what this message reports. Take a video?
quickmic 1709 Posted December 30, 2022 Posted December 30, 2022 2 minutes ago, quickmic said: It's really important what this message reports. Take a video? btw, I assume it's the path, but assuming is not knowing. I need all those details.
BorKon 1 Posted December 30, 2022 Author Posted December 30, 2022 (edited) I found something in kodi log I've attached image of it. Also I took pictures of the message. i just went through other shows. Some shows let me download subtitles some dont. About 3 out of 8 that I tried let me download, rest wont Edited December 30, 2022 by BorKon
quickmic 1709 Posted December 30, 2022 Posted December 30, 2022 (edited) Ok, this is the path. I'm 99% sure the path is too long and that's why it fails. Only option, use shorter filenames. Also this is not specific to tvshows. Every content with long filenames could be affected. EDIT: Even more, this is not related directly to the plugin. Even native Kodi content could run into that issue. Edited December 30, 2022 by quickmic
BorKon 1 Posted December 31, 2022 Author Posted December 31, 2022 Im gonna try to shorten them and check again. 1
