Tikuf 663 Posted November 7, 2013 Posted November 7, 2013 (edited) Try dates http://10.x.x.x:8096/mediabrowser/Users/<UserID>/Items/?ParentID=<ItemID>&recursive=true&MinPremiereDate=20131103&MaxPremiereDate=20131201 Not sure it is right but i do get items returned Edited November 7, 2013 by Tikuf
Luke 42234 Posted November 7, 2013 Author Posted November 7, 2013 did you check swagger? it tells you what the date format should be
Redshirt 1487 Posted November 7, 2013 Posted November 7, 2013 Are MinPremiereDate and MaxPremiereDate even used in that call. I thought they were only used in the GetNextUp call (/mediabrowser/Shows/NextUp)
Luke 42234 Posted November 7, 2013 Author Posted November 7, 2013 Ah good call, it's not. I think I actually took those out when I realized I didn't need them anymore. Upsider, if you need them, i can add them back.
uspider7 17 Posted November 8, 2013 Posted November 8, 2013 Luke, if it's not too much trouble yes, please add it back to the Items call. Basically I'm trying to create a list of shows/episodes that have aired in the past week, 2 weeks 1 month etc... and will use the Location type to indicate if they are available or not for viewing. Also, I did take a look at Swagger but didn't see anything there and thought it just wasn't added yet. I don't see MinPremiereDate & MaxPremiereDate on the /shows/nextup as well. I'm currently set to receive the "Dev" updates, if that makes a difference. Thanks 1
