justinrh 267 Posted December 24, 2022 Posted December 24, 2022 This issue happens often when we are watching recorded movies on the Shield. In case it matters, we usually mute, then FF thru the commercials, then unmute and play. Seemingly randomly, audio will just be null for ~1s (and you can see the sound bar light go off momentarily to confirm it is not the track but the audio signal). We mostly watch TS files with Emby. Here is an example from recorded Avatar last night; I started recording drops at play time 1:36, 1:56, 2:12, 2:29, 2:51. Any idea what is happening? embyserver-avatar.txt MediaInfo avatar.txt I don't recall if we've ever seen it with other apps.
ebr 16337 Posted December 25, 2022 Posted December 25, 2022 21 hours ago, justinrh said: we usually mute, then FF thru the commercials, then unmute and play And this is when you are experiencing the audio drops? It is not uncommon for audio equipment to mute itself when the signal goes in and out. This is to avoid some rather ugly digital distortion that could happen before the signal is completely locked in.
justinrh 267 Posted January 7, 2023 Author Posted January 7, 2023 No. It seems random, but it may be some sorta predicable delta after the FF. It feels like an audio buffer thing, but I don't know if there is such a thing.
Luke 42245 Posted January 18, 2023 Posted January 18, 2023 Can you try updating to the latest version of the sideload build? https://emby.media/emby-for-android.html We've updated our embedded video player to the latest version. Let's see if it plays better with that. Thanks !
